production eyeletting of component leads
Discussion in 'Electronic Repair' started by N_Cook, Oct 26, 2012.
  1. N_Cook
    N_Cook Guest
    Are they just slid over the pins , relying on friction while
    handling/placement and then at soldering it is assumed solder will get
    between the lead and eyelet as well as between eyelet and pcb pad ?
  2. N_Cook
    N_Cook Guest
    Mark Bass amps (Italy) use no-name 0.25 inch input sockets (4 numeral molded
    underneath and 3 pin holes each side of the body) . Eyeletted before
    soldering but after desoldering with fresh solder, to aid pressed/eyeletted
    removal , 2 of the pins have no wetting and dull finish other than solder on
    the cut ends. One pin active , other pin just physical holding ,not
    electrical, but eventually intermittant contact of the active one.
  3. josephkk
    josephkk Guest
    OK. I always thought that the eyelets were pressed into and possibly
    swaged to the board instead.
  4. N_Cook
    N_Cook Guest
    I've never been in production but its easier to align eyelets singly onto
    pins of an IC or in this case socket than try to align all 16 pins of an IC
    into pin sized holes in eyelets already in an array in a pcb. IC socket pins
    , turned or sprung, have location wells to assist this, but eyelets don't
