John Fields
What I need explanined, however, is how are these things SUPPOSED to work?
IOW, what am I doing that is so different from what others do with the NTE
3083?
Can I do something to deal with the leakage?
When you force current through the LED it generates infrared photons
which fall on the sensitive area of the phototransistor and allow
current to flow through the collector-to-emitter junctions of the
Darlington connected transistors.
The Darlington has very high current gain; on the order of 50000, so
even a very small quiescent leakage current flowing into the base of
the first transistor will cause a much larger quiescent current to
flow through the output, which seems to be what you're experiencing.
The leakage can come from three places:
1. The transistor driving the LED may not turn off completely.
You can test for this by measuring the current through the LED with
the [LED driver] transistor in its off state. Simply put a DMM set
to milliamps or microamps in series with the LED, turn the
transistor off and read the meter.
2. Bad opto. Test for this by grounding the LED anode and cathode and
the base of the transistor and then measuring the current which
flows out of the power supply with V+ connected to the collector
and V- connected to the emitter.
3. Non-isolated base. For this one you'll need to have a leakage path
between pin 6 and a positive voltage somewhere. With a gain of
50000, all you need to get a couple of mA into the output is 40nA,
so that's what I'd be looking for. Check for contamination
(moisture, solder flux residue, dirt, etc.) around the opto's base
lead and if you find any, clean it up.
There _is_ a fourth choice, getting rid of that damned Darlington in
the first place and sidestepping the problem. You don't need the gain
since you've got plenty of drive available for the IRLED, so why buy
trouble? If it was me I'd go for a vanilla 4N35, 4N36, or 4N37.
Matter of fact, I've got some 4N35's left over from a project, so if
you want a few of them, gratis, email me with a physical address where
I can send them and I will.
