Problems with Relay !
Discussion in 'General Electronics Discussion' started by shadowflare99, Aug 8, 2012.
  1. shadowflare99
    shadowflare99
    29
    Aug 7, 2012
    Well thank you very much for this plan. But i have a question ...
    Also i see the vin , and the two spst was on fuse and battery ... But i can put this direct on the acc ... Because when the car will goo off all circuit wil not have electricity... Not only hid... But whit this o understand what i need ... Thank you very much !
    Also i presume the two ground of the bottom module is for ground the module on each way
  2. shadowflare99
    shadowflare99
    29
    Aug 7, 2012
    Also what does the off hole ?
    And when they are no electricity did the module reset or it keep his position ?
  3. shadowflare99
    shadowflare99
    29
    Aug 7, 2012
    Last thing ... Did i need to put some diode to protect the circuit
  4. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    Just to help provide a better ground...
    Not, used in this application... It's basically an 'off' override that bypasses the button...
    It will reset to 'off' thus why I suggest hooking it up to an always on +12V...
    You can but it will default to 'off' with every car restart...
    Whoops missed that on the drawing, I have updated it...
    Use a 1N400x (1N4001, 1N4002 etc) rectifier diode, mind the polarity aka the silver band...
  5. shadowflare99
    shadowflare99
    29
    Aug 7, 2012
    Thank you very much, i will buy all these thing and give you picture of my final project :)
  6. shadowflare99
    shadowflare99
    29
    Aug 7, 2012
    I just tried to install The pololu but for some reason .. i connect only the v in and the ground ... and the momentary switch .
    The pololu won t keep it on .. when i release the switch it cut off the power too...
    Help me; (
  7. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    Take a picture... Do you have a load on the output? Are you using the correct voltage range?
