Problems with op-amp input offset voltage
Discussion in 'General Electronics Discussion' started by surendra.jadhav, May 20, 2011.
  1. surendra.jadhav
    surendra.jadhav
    May 20, 2011
    I am facing the problems with offset voltage of the op amp. My op amp has to amplify the very weak signals of the order of 1 to 10mV. As the offset voltage of the LM324 is already 2 to 3mV, it is creating the problems in the output.
    There is no offset pin also so that I can reduce the offset to zero.
    What should I do in this case in order to reduce the offset?
    Surendra.
  2. (*steve*)
    25,497
    2,839
    You might want to look into chopper stabilised op-amps.
    Look here, here, and here.
