Electronic Engineer
- Jun 22, 2017
- 1
- Joined
- Jun 22, 2017
- Messages
- 1
Use of LTspice on a MAC - experiences.
Electronic Engineer
Today, 11:53
Sent Items
Hi All
I have been trying to install and use LTspice 1V on my MAC computers. Here is my experience:
The 2016 version does not use or need the WINE system as it is written to work directly on the intel PC MAC.
I can install it onto both my MAC 15 Deskpro (2010 version) and the MAC Air (2012 version) and it works OK with programs that others have written in terms of developing circuits and simulating them on the MAC computers.
You need to use mouse right click to get at most commands and does not support much in the way of top of the screen drop down menu items (File Edit and a couple of other items but simulate is not up there now.
To get at the simulator and editing commands you need to use mouse right click and access commands from there.
It you try to build your own circuits you can do this and they build fine. Reading some tutorials you can (on a windows PC) open the Simulate menu item at top of the screen and go to edit simulation CMD then simulate the circuit. So it appears to work on a PC.
I tried a few things with the MAC version:
I still do not have a PC but sometime soon will try to install Parallels on my MACs then try to get Windows 10 installed and try the Windows version.
Still it would be nice to see if the MAC version can be got to work.
Finally, I think their might be an LTSpice update on the 1V version but have not come across it yet?
Would be interested in anyone who has seen this problem and has a workaround.
I have worked as a Electrical/Electronic Engineer most of my life (over 50 years) and covered a fair few things over that time (Analoge/Digital/ verilogHDL/VHDL/Programming in Assembly/C/C++/occam).
Including FSM based design, and wrote a couple of books to.
Cheers
Peter
[Mod edit: removed a bunch of blank lines to improve readability]
Electronic Engineer
Today, 11:53
Sent Items
Hi All
- Draft -> SPICE directive S and typed in tran 0 5 0.02 then pressed OK to get this entered onto my circuit (did this) but on when RUN pressed - or mouse right button. the same problem happened - 'no analysis commands found' message appeared.
- I then tried accessing the software update and it came back with a message 'Unmounted failed for /volumes/LTspice Installation' so it seems to be not allowing new circuits to be developed, only existing ones.
Cheers
Peter
