Problems about magnet moving back n forth inside da solenoid
Discussion in 'Electronic Basics' started by jamezun, Nov 2, 2005.
  1. jamezun
    jamezun Guest
    I got a coil and a rod magnet is moved back and forth. In order t
    obtain the greatest current, should the rod be as long as possible
    What factors affect the ac current that will be generated? no of coi
    per length, strength of magnet and? What formula should I use
    And how can I keep the output voltage and out current steadily
  2. GotCoffee
    GotCoffee Guest
    e=beta*length*velocity
    Beta is magnetic flux density measured in Tesla (how strong the magnet
    is).
    Length is the length of the conductor in the magnetic field.
    Velocity is how fast the coils or magnet is moving in meters per
    second.
    To keep a constant voltage level, keep the magnet moving at the same
    speed, preferably around in a circle like an alternator. To obtain the
    greatest current, you want a strong magnet, a lot of coils and fast
    movement.
    Another formula to consider is:
    e=(number of turns of wire)*(change in magnetic flux measured in
    Webers)/(change in time)
    The above formula shows that the instantaneous voltage is inversely
    proportional to time.
