A
Adrian Tuddenham
I am using a TDA7295 to drive a nominal 12 - 15 ohm load. On the test
bench the load is a chunk of electric fire element with connections made
by adjustable straps, so it is slightly inductive. The load in the
final version will be a loudspeaker voice coil on the end of some
unavoidably long wiring.
The TDA7295 data sheet claims "No Boucherot cell" but does not elaborate
any further. I am using the recommended circuit and the gain is set by
a divider of 22k and 680 ohms, exactly as specified.
An oscilloscope shows bursts of H.F. oscillation at two points on the
output waveform as it approaches +Vcc and -Vcc. These only occur on
load and they disappear if the signal amplitude is reduced below
approximately half the maximum peak-to-peak voltage. The power supply
decoupling is as recommended by the manufacturers and is mounted within
0.25 " of the chip pins.
To eliminate the possibility of earth loops or inductive coupling from
the output currents by temporarily connecting the load across different
signal and earth points in the layout. I have connected the signal
generator direct to the chip input. Neither of these tests made any
difference. The effect is independent of signal frequency below 25
Kc/s; but above that frequency it rapidly fades out.
The only thing which has removed the oscillation is the addition of a
Boucherot/Zobel network across the output terminals.
1) Have I missed something?
2) Is this one peculiar faulty chip?
3) Is the manufacturer making a false claim about needing no Boucherot
Cell (or a claim which is only true under exceptional circumstances)?
