Problem with Siemens Gigaset 2415
Discussion in 'Electronic Repair' started by C Yeung, Aug 13, 2003.
  1. C Yeung
    C Yeung Guest
    I have a Siemens Gigaset 2415 cordless phone. It seems that after I
    talked on the phone for about 10-15 minutes, the other side could no
    longer hear me while I could still hear it clearly. If I switched to
    another phone, everything worked fine. If I switched back to the 2415
    (2400) handset, it worked for a short time. The batteries are all fully
    charged. Just wondering if anyone knows what could be the problem!
    Thank you and best regards!
    Cliff.
  2. Jerry G.
    Jerry G. Guest
    A component(s) have become thermo sensitive in the transmit section, or
    in the audio preamp section in the handset, or in the receive processing
    section in the base. The fault must be isolated. Most likely the fault
    is in the handset. Because of the way you are describing the fault, I
    doubt it is a cold solder connection.
    These units use high density LSI technology with multi layer boards. I
    doubt very much that you are even the corner service shop and even most
    large service centres can service this phone at the component level.
    You will have to send it to the authorized service centre for Siemens
    phones. If you consult the instruction manual, or call Siemens
    directly, they can advise you of the closest service rep to you.
    Most of the time, when these phones are sent for service, the complete
    circuit board or module is changed to fix them. This is most cost
    effective when considering the cost of the parts and labour. They only
    have to re-install the new board and check its calibration.
    When sending the phone for service, you must send the handset, power
    supply, and base unit. This way they can check it as a complete system.
    Greetings,
    Jerry Greenberg GLG Technologies GLG
    WebPage http://www.zoom-one.com
    Electronics http://www.zoom-one.com/electron.htm
    Instruments http://www.zoom-one.com/glgtech.htm
    Cliff.
  3. C Yeung
    C Yeung Guest
    Thanks! I suspected it as well since my wife was complaining about the
    batteries were getting hot after a while. I had changed them to NiMh. I
    will switch it to NiCd to see if it will help. If it has no improvement,
    I might as well get a new handset since it will cost me less to buy a
    new one than to send it to repair.
    Best regards!
    Cliff.
  4. jakdedert
    jakdedert Guest
    Duhh...you swapped out NiCads for NiMhs? Whenever something gives out,
    always reverse your last step....
    Previous discussions in this ng will point out the obvious flaws of this
    action. Use Google Groups to access several lengthy threads on the topic.
    Hopefully you haven't done any permanent damage; but doubtless the problem
    is related to the battery swap.
    jak
