Problem with SHT75 Humidity/Temperature Sensor
Discussion in 'Electronic Basics' started by Sensorboy, Dec 14, 2004.
  1. Sensorboy
    Sensorboy Guest
    Hello Sir,
    I am using a SHT75 humidity sensor. I am interfacing SHT75 with the
    MSP4301232 Microcontroller. The problem I am facing is - after writing the
    control byte; the SHT75 does not acknowledge proper receipt of control
    byte. I have verified the timings and found them to be good enough. I have
    also tried connecting a pull up resistor for the data line, but the SHT75
    does not drive the data line low.
    I am sending you a snapshot of the CRO display without the pull-up
    resistor. Here the data line is low after transmission of the control
    byte, but the data line is low after the Microcontroller release the pin
    and not by the sensor. I would appreciate if you could explain the problem
    behind this.
    Also, if you give me some idea of how I would test my Humidity sensor, I
    would appreciate.
    Regards,
    Krishna
  2. deyaya
    deyaya
    Mar 28, 2010
    Dear Krishna ,
    I have the same project for my final diploma at University " Politehnica" in Bukarest. Could you be so kind to help me and provide me the schematic ?
    Many thanks in advance,
    Deyaya
