problem with receiving n transmitting
Discussion in 'General Electronics Discussion' started by swatz, Apr 3, 2014.
  1. swatz
    swatz
    Apr 3, 2014
    i'm doing a project which requires to send small amount of data wireless from one MCU to another (using ATmega328p). i'm using RF Serial Data Link UART, 2.4 Ghz RF module from sunrom technologies (http://www.sunrom.com/161). but i'm receiving some garbage value like 255 again n again. so please him me out here.
    Transmitting Code:
    #ifndef F_CPU
    #define F_CPU 16000000UL // set the CPU clock
    #endif
    #include <avr/io.h>
    #include <util/delay.h>
    #include <stdlib.h>
    #define BAUD 9600
    #define BAUDRATE ((F_CPU)/(BAUD*16UL)-1) // set baud rate value for UBRR
    // function to initialize UART
    void uart_init (void)
    UBRR0H = (unsigned char)(BAUDRATE>>8);
    // shift the register right by 8 bits
    UBRR0L = (unsigned char)BAUDRATE; // set baud rate
    UCSR0B = (1<<TXEN0)|(1<<RXEN0);
    // enable receiver and transmitter
    UCSR0C = (3<<UCSZ00); // 8bit data format
    void uart_transmit ( unsigned char data)
    while (!( UCSR0A & (1<<UDRE0)));
    // wait while register is free
    UDR0 = data;
    // load data in the register
    int main()
    unsigned char i=8;
    uart_init();
    while(1)
    uart_transmit(i);
    _delay_ms(200);
    return 0;
    Receiving Code:
    #ifndef F_CPU
    #endif
    #include <avr/io.h>
    #include <stdlib.h>
    #include "lcd.h"
    // define some macros
    #define BAUD 9600 // define baud
    UBRR0H = (unsigned char)(BAUDRATE>>8); // shift the register right by 8 bits
    // function to receive data
    unsigned char uart_recieve (void)
    while(~(UCSR0A) & (1<<RXC0));
    // wait while data is being received
    return UDR0;
    // return 8-bit data
    // main function: entry point of program
    int main (void)
    uart_init();
    SetupPorts();
    LCD_Init();
    while(1)
    LCD_Integer(uart_recieve());
    // display the received value on LCD
    _delay_ms(100);
    // wait before next attempt
    return 0;
