Categories
Platforms
Content
hi ramin
welcome to the forums
Google solves many problems ... the 2N6027 is neither NPN or PNP as it isnt a standard bipolar transistor .... its a Programmable Unijunction Transistor --- PUT
a PUT is a diode with a gate connection so you have Anode - Gate - Cathode
cheers
You need to tell us exactly what it is doing.
Also, do you have a multimeter?
Also, can you post a picture of your breadboard so we can check for wiring errors.
No, I need an image clear enough that I can read the bands on the resistors and see if the LED is around the right way.
You still haven't told us what it's doing or whether you have a multimeter.
That's an excellent photo!
I need to make a bit of a guess that the resistor that is partially obscured is red-violet-orange.
Are you telling us that the LED is not flashing (it will be a brief flash with a longer delay between flashes)?
You could connect your multimeter on a low voltage range across the 2.2uF capacitor. You should see the voltage changing. If your multimeter is fast enough (or the flashing slow enough) you should see it slowly rise then rapidly fall (and repeat...)
It's probably a date code. That essentially means there is no difference.
Perhaps you destroyed them?
i changed my PUT with another one and it's working now!
now my question is :
is first PUT is burned? because i bought all of them from same shop and all of them are new but they have different name. That one is not working is named with 2N6027 901 and the one is working is named with 2N2067 610. so what's the problem?
Hi steve,
I am new here. I am facing same problem what ramin110 had faced. I am doing exactly what it is in the book, but I am not getting output. I am using 2N6027 110 since that is the only one available in the store. I've noticed one thing. When I connect the circuit other way round i.e cathode pin to resistor and capacitor combination and anode to LED, then LED glows (doesn't flash though). Why is that so? It's like same circuit but just pins interchanged. I did this accidentally at first so I thought I burnt PUT, then I took another one and this time I inserted properly but didn't work. Do you think it's PUT fault just like ramin110?
