Problem with Panasonic TV and tv cycling
Discussion in 'Electronic Repair' started by bk2azmom, Jun 4, 2004.
  1. bk2azmom
    bk2azmom Guest
    All of the sudden today, our panasonic tv started cycling channels
    non-stop and also switching into Component, Video 1, 2, &3 modes. The
    remote also does not work - even though I changed the batteries.
    Any ideas on what's causing this and how to fix it?
    HELP! :)
  2. Jerry G.
    Jerry G. Guest
    This can be a fault in the uPC area, or there is a shorted front panel
    control.
    Is it possible that someone washed the screen, and let some liquid drop in
    between the screen and the mask?
    In anycase the set will have to be properly serviced. If liquid got in
    somehow, there may be some parts to change.
    When cleaning a monitor or TV screen, you should dampen (not too wet) a soft
    paper towel with water. Do not put any liquid directly to the screen. Use
    the dampened paper towel to clean the screen. Then use a dry soft paper
    towel to clean. Avoid strong cleaners, because any screen coatings can be
    damaged.
    Jerry G.
    HELP! :)
