Problem With OPAMP
Discussion in 'General Electronics Discussion' started by sid2286, Oct 28, 2016.
  1. sid2286
    sid2286
    102
    Aug 24, 2011
    Dear All,
    I have designed a circuit and it is working ok in parts: Attached Circuit diagram:
    working part:
    1. I am getting output at TP5,
    2. when i connect the output from TP5 to TP7 directly my XTR111 and Comparator section is working ok.
    problem:
    1. I have used an OPAMP since when i Set zero (say 1V) and while doing calibration using SPAN i set (say 2V) when I remove the calibration set up then reading does-not come back to 1v but comes to 1.5V. ( 1st How do i resolve this problem)
    2. So i tried using the OPAMP 604, but i am not getting any output at TP6, for 1v , ideally i should get -1V which is not happening.
    3. next OPAMP is also not working.
    4. what i noticed is at the input of R11 i am getting 1v but at the otherend of R11 it is getting reduced to 450mV (Not sure why)
    when i remove R14 i do get 1v at R11. but i am clueless how why that is happening.
    please help me reslove this problem
    Sid
  2. davenn
    davenn Moderator
    13,669
    1,891
    do you understand how op-amps work ?
    I suspect, not quite
    What did you expect to see at the inverting input side of R11 ?
    lets take a look at just that section of your circuit
    have deleted a bit of irrelevant stuff to make the layout easier to read
    do you know the 2 rules of Op-Amps, keeping in mind that they are for an idea op-amps, but are applicable for general situations
    just in case you don't .....
    Rule 1) no current flows in or out of the 2 inputs
    Rule 2) The op-amp tries to keep the inputs at the same voltage
    now keeping rule 2 in mind, that should answer your Q I quoted
    so if you disconnect the feedback resistor, how do you think that affects Rule 2 ?
    Dae
  3. sid2286
    sid2286
    102
    Aug 24, 2011
    What did you expect to see at the inverting input side of R11 ?​
    since the R13 is connected to ground there should have been no voltage at pin 2 i.e. to say both the pins inverting and non inverting pins are at 0 potential for me to get a -1V at the output. but that is not happening, I dont the reason where i am going wrong.
    request you to help.
  4. CDRIVE
    4,960
    648
    May 8, 2012
    I don't see any of these OpAmps powered from a split (±) supply. What I do see is the (-) power pins at GND. So how can the OpAmp's output swing below zero? :confused:
    Chris
  5. davenn
    davenn Moderator
    13,669
    1,891
    It cant but that may not be an isdue depending on how its being used
    That was going to be a future Q from me once we got the basic op amp operation sorted out
    Maybe its time for that Q now ....
    A negative output cannot be generated from a positive only supply
    (Not that im aware of any way)
  6. (*steve*)
    25,418
    2,788
    Without inductors or switched capacitors (but I don't think that's relevant here)
    davenn likes this.
  7. CDRIVE
    4,960
    648
    May 8, 2012
    Maybe we should be asking Sid why he thinks he should measure -1V on the output pin?
    Chris
  8. sid2286
    sid2286
    102
    Aug 24, 2011
    Oh now I got it., I am extremely sorry for posting this one. I simply read the datasheet which say the opamp works on 0 to +5ve supply, without furthermore thinking I used it.
    But now that I have used it, is there anyway I can tweak it or should I be replacing the opamp and use 7660 for negative supply ?
    davenn likes this.
  9. davenn
    davenn Moderator
    13,669
    1,891
    yeah you really should be using a split rail supply op-amp
    maybe play with some TL072's or 074's
