Problem with my PC' speakers
Discussion in 'Misc Electronics' started by Chaos Master, May 22, 2004.
  1. Chaos Master
    Chaos Master Guest
    hey people
    Today I was listening to music in my PC when a very irritating problem started:
    Suddenly the sound started to go "muffled".
    You barely can listen to voices.
    My sound card has a few settings for some sort of "effects" on the audio but
    those were disabled by me.
    My sound card is a Sound III (Aztech).
    Is it time for new speakers?
    Chaos Master® | "I'm going under,
    Posting from Brazil! | drowning in you
    ICQ: 126375906 | I'm falling forever,
    ask for e-mail/MSN | I've got to break through"
    ---------------------. -- Evanescence, "Going Under"
  2. Jerry G.
    Jerry G. Guest
    You will have to try another set of speakers or a sound card to determine
    where the fault is. Or, try the speakers on another computer.
    Jerry G.
    hmm
    hard to say.
    i assume you have amplified speakers ?
    what you should do is first plug in a head
    set using the same output as you are now for the
    speakers.
    if the sound is ok then you know its speakers ! other
    wise use some of your money and buy a new sound card.
  3. Chaos Master
    Chaos Master Guest
    mv /var/posts/Jerry G./ /dev/null:
    Solved it by moving the speaker' cable. I think there was a short or
    something...
    []s
  4. I had the same problem with my first computer.I discovered it was the poor
    quality of the ac-97 onboard audio.Bought a soundblaster 128,a QDI advance 9
    and a voodoo 3 3000 (state-of-the-art components, then).
  5. Chaos Master
    Chaos Master Guest
    Tzortzakakis Dimitrios() showed us the
    following results:
    If this was onboard audio.. but no, it's a good old ISA sound card - great for
    MS-DOS programs. The audio quality is not the best, but very good, considering I
    got the card for very cheap (to replace a Rockwell sound card that was bad).
    []s
    Win 98 + BB4Win | I'm falling forever,
    Slackware Linux | I've got to break through"
