Problem with LCD & PIC16C54C
Discussion in 'Electronic Design' started by [email protected], Mar 26, 2007.
  1. Guest
    Hi All,
    Just bought a BATRON 4 line LCD. Tried to get it moving by displaying
    a character. However, to no avail, all it displays are black boxes.
    Below is the code I used for the PIC16C54C.
    LIST P=16C54 ;This tells the assembler which device is required
    ;***************** Hardware Definitions - Specific to the PIC
    PORTA EQU 0x05 ; Physical Address on PIC
    PORTB EQU 0x06 ; Physical Address on PIC
    STATUS EQU 0x03 ; Physical Address on PIC
    STAT_BANK EQU 0x05 ; Bit 5 to switch bank
    ;************** Hardware Definitions - Specific to the Circuit
    LCD_RS EQU 0
    LCD_EN EQU 1
    ; LCD SET DDRAM Address
    LCD_LINE1 EQU 0x80
    LCD_LINE2 EQU 0xC0
    LCD_LINE3 EQU 0x94
    LCD_LINE4 EQU 0xD4
    ;************************** GENERAL PURPOSE REGISTERS
    COUNTHIGH EQU 0x08
    COUNTLOW EQU 0x09
    ;LCD_DATA EQU 0x0A
    ;******************************** CONSTANTS
    timehigh EQU 0xFF
    timelow EQU 0xFF
    ;*************************** Start of the Program
    ORG 1ffh ;This tells the assembler where to place the code
    goto START ;1ffh is the Reset Vector (Startup location) for PIC
    16C5x's
    ORG 0h
    goto START
    ; SUBROUTINES
    DELAY ;delay 20mS
    movlw timehigh
    movwf COUNTHIGH
    movlw timelow
    movwf COUNTLOW
    delayloop
    decfsz COUNTLOW,f
    goto delayloop
    movlw timelow
    movwf COUNTLOW
    decfsz COUNTHIGH,f
    goto delayloop
    RETURN
    SDELAY ;delay
    movlw timelow
    movwf COUNTLOW
    sdelayloop
    decfsz COUNTLOW,f
    goto sdelayloop
    RETURN
    FUNCTIONSET
    CALL SDELAY
    MOVLW 0x38
    MOVWF PORTB
    BSF PORTA,LCD_EN
    CALL SDELAY
    NOP
    BCF PORTA,LCD_EN
    RETURN
    SENDTOLCD
    CALL SDELAY
    ; MOVWF PORTB
    BSF PORTA,LCD_EN
    CALL SDELAY
    NOP
    BCF PORTA,LCD_EN
    RETURN
    START
    ;***************************** Initialize PIC
    CLRF PORTA
    CLRF PORTB
    BSF STATUS,STAT_BANK ; At Bank 1 now
    MOVLW 00H
    TRIS PORTB ; Port B all o/p
    MOVLW 00H
    TRIS PORTA ; Port A i/o = 0000 0000
    BCF STATUS,STAT_BANK ; At Bank 0 now
    ;***************************** Initialize LCD
    CALL DELAY
    BCF PORTA,LCD_RS
    CALL FUNCTIONSET
    CALL FUNCTIONSET
    CALL FUNCTIONSET
    CALL FUNCTIONSET
    CALL SDELAY
    MOVLW 0x08 ; Display ON/OFF = display off, cursor off, blink off
    MOVWF PORTB
    CALL SENDTOLCD
    MOVLW 0x01 ; Clear Display
    MOVWF PORTB
    CALL SENDTOLCD
    MOVLW 0x07 ; Entry Mode Set
    MOVWF PORTB
    CALL SENDTOLCD
    ;****************************** SEND DATA TO LCD
    MOVLW 0x0F ; Display on, curson on, blink on
    MOVWF PORTB
    CALL SENDTOLCD
    MOVLW LCD_LINE1 ; DDRAM Set
    MOVWF PORTB
    CALL SENDTOLCD
    ;***********END OF INSTRUCTION SET, START OF
    DATA*************************
    BSF PORTA,LCD_RS
    MOVLW 41h
    MOVWF PORTB
    CALL SENDTOLCD
    END
    I am not sure what went wrong. As for the circuit, i tied a crystal at
    the OSC1 & OCS2 of the PIC with 2 caps.
    Thanks in advance
    ywz
  2. blisca
    blisca Guest
    are you talking about a hd44780 or equivalent alphanumeric display?If yes
    the black boxes are commonly due to wrong initialization.Can you post a
    link to the display datasheet?
    anyway if you are not still shure about your firmware how can you use a
    16C?If i remember it is One Time Programmable.I think the use of a 16F
    should be better.
    Correct me if i am wrong.
    Diego
  3. Guest
    Hi Diego,
    The datasheet link -> http://sg.farnell.com/jsp/endecaSearch/partDetail.jsp?SKU=9448977
    The 16C has a cerdip version where i can erase it with UV.
    I followed the initialization in the datasheet of the LCD controller,
    however it still does not work. You can refer to the code posted
    previously if there is any mistake.
    Could it be due to the Vo and Vdd of the LCD? I had 2 separate power
    supply for these two pins. Vo=5.35V, Vdd=5V with both ground tied to
    Vss.
  4. blisca
    blisca Guest
    CALL Delay???
    CALL Delay????
    CALL delay????
    CALL Delay??????
    look for the KS0066 initialization sequence,i guess you have to add some
    delay after LCD_EN is turned low.At a certain point the busy check at bit 7
    can be performed,i suggesto to use it.The software will be more complicated
    ,but you will improve speed and avoid conflicts
    well,if the Vo is too close to ground the background appears very dark but
    you should be able to see the characters,anyway put a trimmer(10 Kohms or
    even 47Kohms) between ground vdd,cursor to Vo
  5. Guest
    CALL FUNCTIONSET
    CALL Delay??? <--- Already got a delay in FUNCTIONSET
    CALL FUNCTIONSET
    The sequence which I used is smilar to that of the KS0066.
    No effect, still same black boxes.
  6. blisca
    blisca Guest
    i saw,but maybe,maybe it should be performed after LCD_EN turned low
    strange,at least turning pot towards VDD should turn the display white
  7. Guest
    haha, I just tried that before reading this post. But still same
    results... ;)
  8. Guest
    btw, when I run the program with MPLAB SIM, when the code runs till
    the end, "Stack underflow" occurs. Is it what it should be?
  9. Dennis
    Dennis Guest
    DO you have the spec sheet for the display? Some of them require a
    negative contrast voltage - usually the extended temp range ones.
  10. For the display you are using, note Vlcd. Note that this requires V0, to
    be -3v typically. Note also, that the Samsung controllers, typically need
    slightly longer after boot, before being ready to operate, that the
    Hitachi controllers, which are the 'standard', which most of these
    emulate. Something like 30mSec after power is applied, is needed to be
    'safe'.
    Best Wishes
  11. Guest
    Yup the contrast voltage is -3V. The PIC is working becoz I tied a LED
    to one of the o/p. However, the LCD still does not display. It could
    be due to the wrong init. sequences or that data are not sent to the
    LCD correctly.
    CALL DELAY
    CALL DELAY
    CALL DELAY
    BCF PORTA,LCD_RS
    BCF PORTA,LCD_RW
    CALL DELAY
    CALL FUNCTIONSET
    CALL FUNCTIONSET
    CALL FUNCTIONSET
    CALL SDELAY
    MOVLW 0x3F ; Function set
    MOVWF PORTB
    CALL SENDTOLCD
    CALL SDELAY
    MOVWF PORTB
    CALL SENDTOLCD
    CALL SDELAY
    MOVWF PORTB
    CALL SENDTOLCD
    CALL DELAY
    CALL DELAY
    CALL DELAY
    CALL DELAY
    CALL DELAY
    MOVLW 0x06 ; Entry Mode Set
    MOVWF PORTB
    CALL SENDTOLCD
    CALL SDELAY
    FUNCTIONSET
    CALL SDELAY
    MOVLW 0x30 ; 2 line, display on
    MOVWF PORTB
    BSF PORTA,LCD_EN
    CALL SDELAY
    NOP
    BCF PORTA,LCD_EN
    CALL SDELAY
    RETLW 0
    SENDTOLCD
    CALL SDELAY
    BSF PORTA,LCD_EN
    CALL SDELAY
    NOP
    BCF PORTA,LCD_EN
    CALL SDELAY
    RETLW 0
    Any help is appreciated. btw .... could the problem be due to the 4Mhz
    osc i am using becoz the datasheet has a condition Fosc=270KHz
    ywz
  12. Guest
    Hi Guys,
    Finally got the LCD to display a couple of chars. The problem actually
    lies in the initialization part of the datasheet. However the display
    only shows:
    A A A A A A A A x x x x x x x x x x x x
    _ _ _ _ _ _ _ _ x x x x x x x x x x x x
    x x x x x x x x x x x x x x x x x x x x
    x denotes black boxes.
    _ denotes blanks.
    How come these boxes exist?
  13. Donald
    Donald Guest
    You still have not initialized the display correctly.
    The data sheet is most likly correct, your code is not correct yet.
    donald
Similar Threads
Loading...
