PROBLEM with Fox International
Discussion in 'Electronic Repair' started by Brad, Mar 28, 2008.
  1. Brad
    Brad Guest
    Is anyone else having problems getting the correct part/s from
    Fox International?
    They keep sending me the same wrong IC for an RCA TV (I don't have the
    service manual). A Fox tech told me that Thomson said this part is a
    "substitute".
    After, I downloaded a .PDF file for the so called "substitute",
    based on the actual number on the device, internally it is different than the
    original device (based on .PDF file for original).
    I then called Thomson and finally got hold of someone who told me that
    the part number (Fox said is a "substitute") is INCORRECT.
    Thanks in advance, Brad
    Before you type your password, credit card number, etc.,
    be sure there is no active keystroke logger (spyware) in your PC.
  2. BH
    BH Guest
    They're usually pretty good. How different was the number?
    Bruce
