A
Adam
I have a light fitting that takes two tubes wired in series in what I
believe is the standard configuration. I've replaced both tubes twice
and replaced both starters with ones taken from fluorescent fittings
that work. I've also checked the ballast to make sure it hasn't failed
open (ohmmeter with the power off: 50 ohms) but I understand ballasts
rarely fail. I've gone around it with a voltmeter and an ohmmeter
checking for any other open circuits and all the wiring seems good.
(This is in the UK, so 240VAC 50Hz.)
The only difference is that the original tubes that worked were labelled
"18W/41" and the replacements (available near my house) are "18W/35".
They have the same length and diameter.
Any suggestions?
Adam
Any suggestions?
Adam
