problem with DS1307
Discussion in 'Electronic Design' started by hitu, Mar 16, 2007.
  1. hitu
    hitu Guest
    I have made a simple board using AT89c52 and DS1307. I works fine
    normally, but during sudden power failure and restore of power,
    sometimes the time stored in RTC is corupted. I tried by making
    seperate power supply to RTC and early RESET to micro controller
    during power fail, still the problem is not solved. Can you help me ?
    Hitu
  2. It's been a year or two since I first played with a 1307 and I recall having
    problems similar to what you're saying. I added a coin-cell backup battery
    to keep the time alive when the power failed. IIRC, it has to do with
    having power interrupted when you are "talking" to the 1307. Try enabling
    "brown out detect" if you have that option so that the processor won't try
    doing I/O without enough voltage available.
  3. TT_Man
    TT_Man Guest
    I have had the same/similar problem and have given up....The RTC is now
    strapped to VCC and we don't rely on it's memory to re-instate the true
    time.Then we just ran the chip as a time counter. We still had problems..
    Now we've given up altogether and use an RTC derived from the CPU XTAL
    The main problem seemed to be that the RTC chip would lock out the CPU on
    powerup, maybe getting the SDA SDC in a twist. Being backed up by a coin
    cell meant we had to remove the chip to 'unlock it'. Bloody nightmare. :(
    There's no brownout on a 52 and I doubt that will help.......
  4. Eeyore
    Eeyore Guest
    You could use a brownout detector and feed that to an interrupt. I'm sure some
    8051 varaint now have brownout detection btw.
    Graham
  5. James Beck
    James Beck Guest
    We use the DS1307 in a couple products (thousands of units in the field)
    and I have never run into any problems other than being interrupted by a
    power fail in the middle of a write and we only write when a human needs
    to set the time. I did make one small change over how most people might
    run the IC, and I don't know if this might be why I have not had any
    problems, but I use a small coin cell hooked to the Vbat input and I use
    an output pin from the MCU to supply Vcc to the 1307. On power up the
    rest of the system is initialized and before I use the clock for the
    first time I pull that IO pin high. That lets me do a couple of
    different things. It let's me go into deep sleep where the clock is
    powered down and the MCU has built in brown out detection, so when the
    power fails and the reset gets pulled low, the IO pin goes back to high
    impedance mode cleanly killing the power to the DS1307 and it will not
    get it back until the system completely reinitialized. Anyway, I may
    try strapping one of them straight to Vcc to see if the date and time
    get buggered up, hmmmmmm.
    Jim
  6. TT_Man
    TT_Man Guest
    Excellent idea..... I have just gone back and looked at our design. I was
    mistaken, we use the DS1377( not 1307). This is driven by a DS1218 Vcc/Batt
    switching chip,that also controls our /WE on the 32K CMOS ram. We get no
    problems with RAM at all. Al my previous comments refer to this setup.
  7.
