Problem with Clamp Meter (Benning)
Discussion in 'Troubleshooting and Repair' started by redoomed, Nov 9, 2018.
  1. redoomed
    redoomed
    Nov 4, 2016
    Hello guys!
    I have a digital clamp meter (Benning CM 1-2, I have uploaded two photos of the pcb board) and it has two problems:
    1. The Clamp meter's two cables are disconnected from the PCB board and I don't know where exactly to solder them. However I have seen two possible pins on the board (I marked them with a red circle) that might be the right place for the two wires
    2. The device does not turn on. Even with new batteries, when I turn it on nothings happen in the screen.
    I have uploaded two photos. Have you any idea?
    Thank you very much in advance
      File size:
      137.1 KB
      6
      File size:
      144.1 KB
      6
  2. (*steve*)
    25,178
    2,690
    I would hazard a guess that they connect to the wires coming from the "jaws" of the clamp meter.
    Surely there are 2 wires somewhere that are not connected to anything?
  3. kellys_eye
    kellys_eye
    4,284
    1,145
    Jun 25, 2010
    Did you insert the batteries correctly? Sure they are new/charged?
    The circled connections are for the clamp.
    Looks to me as if there is corrosion between some of the processor pins. There's also a dodgy soldered link beside the red connector - potentially indicating the track 'blew out' under previous fault condition and has been soldered back in place..... sure this meter isn't 'used' or from a dodgy source?
