Jeff Wiseman
I have an Adcom GCD-600 carousel that is moderately used and
about 11 years old. I purchased it used about 6 years ago and it
worked fine up to about 3 years ago when it started having
problems when cold. After cleaning the laser to no avail, I
replaced it with another player about 2.5 years ago so this unit
has been setting in a box. Unfortunately, since I've been out of
work for quite a while, I've had to sell nearly all my audio
stuff including the CD player I had replaced the GCD-600 with.
Now the Adcom is all I have so I'd like to try and get it going
cheaply if possible.
The problem started gradually and increased over time. When the
unit is first turned on and a disk is selected to play, A series
of clicks can be heard but the track won't start for a few
seconds. Sometimes it won't seem to start at all (or I give up
too quick). I've seen this on different tracks so I'm not sure if
track position has anything to do with it.
I've discovered that if I try other tracks until I find one that
will play, I can play it for amout 2 minutes or more and then at
that point the problem seems to have gone away. Everything seems
to start and play fine after this point. Presumably the "warming
up" of the laser may have something to do with this.
My questions:
1) What is the most likely cause of this failure? I had the unit
open once to clean the laser but that didn't help at all.
However, I didn't check the "sticky grease" or "worn out spindle" possibilities.
2) The unit IS over ten years old and the suspect "warm up" issue
of the laser implies to me that the laser is on it's way out. Is
this an appropriate assumption and a typical failure mode? This
seems to run contrary to what I've heard about CD lasers
basically working fine up to the point where they totally fail.
If this assumption is correct, I would further assume that a
tweak on the laser bias might solve the problem. Does this
thinking make sense?
3) Adcom tends to control who has access to their service
manuals--besides, I can't afford purchasing one anyway (or even
justify a cost for an 11 year old player). I am very comfortable
working with electronics but the only test equipment that I have
is a quality Fluke DMM (an old model 27). Where could I find
appropriate tracking alignment procedures and
literature/schematics for the Adcom (e.g., where are the
adjustments located, etc.)?
4) Is there any online information or general FAQ dealing with
laser alignments, etc.?
- Jeff
My questions:
- Jeff
