W
W Letendre
Using Atmel ATF22V10CZ PAL in servo amp, as Hall sensor decode for
motor commutation. Logic is strictly combinational (no clock used, no
feedback from outputs to inputs 'cept through motor, via motion). Used
power down version of PAL cause Hall state transitions are slow, by
electronic standards, and the power savings were nice, if not
absolutely necessary.
Problem I'm seeing is, once in a great while, PAL "forgets" to change
output state in response to change in Hall lines. Result not too hard
to catch, in post mortem, 'cause motor stalls, then waits patiently at
"zero torque" point for hapless engineer to attach scope probe to drive
PCB. Result is clear: PAL outputs and inputs don't match source code
file. But, if you "nudge" motor to next Hall transistion, resumes
normal operation ,and PAL pins show expected logic levels, all six
legal Hall states, 'till the next failure event.
Was concerned that the rise times on the Hall signals might be too slow
for reliable triggering of "Atmel's patented Input Transition
Detection (ITD) circuitry" since the Hall sensors are Open Drain
devices. So, decreased pull up resistor from 10K to 1K, reduced
capacative bypass from 0.1uF to 0.01uF. No help.
Any idea what the gremlin here might be? Should mention, this symptom
shows up in about 20% of drives built to date. Going through the
exercise now of peeling off checksum labels and checking date codes, to
see if we might have a bad batch of PALs!
W Letendre
W Letendre
