Problem with 2.8 -> 5V power supply
Discussion in 'Power Electronics' started by jozef007, Nov 9, 2019.
  1. jozef007
    jozef007
    23
    Nov 9, 2019
    I having problem with power supply, which for inputs from 1.8 - 2.8 V should generate 5V on outputs.
    Currently I don't have load on output, I just measured voltage there, which was around 1.5V and circuit TPS61032RSAR started overheated, current on input was 440mA. I tested thoroughly all 16 pins, there was not a issue. Can some please look into, not sure, what I'm doing wrong. I attached schematic, bellow is link for IC. Thx
    http://www.ti.com/lit/ds/symlink/tps61030.pdf
  2. Alec_t
    Alec_t
    2,911
    791
    Jul 7, 2015
    Welcom to EP!
    Try adding a nominal load, say 1k, and measure again.
  3. jozef007
    jozef007
    23
    Nov 9, 2019
    Hi Alec, I try it but result is the same. Can you please assess if my schematic has a merit? I calculated parts, want to be sure, that they are correct.
  4. Alec_t
    Alec_t
    2,911
    791
    Jul 7, 2015
    Your circuit may be oscillating uncontrollably.
    I don't see the 100nF decoupling cap (as recommended in the datasheet), which should be directly across the supply pins of the IC.
    Does your circuit layout follow the datasheet (section 13) recommendations? Hopefully the circuit isn't on a breadboard!
  5. jozef007
    jozef007
    23
    Nov 9, 2019
    I used SMD's so whole board was designed, hopefully we are talking about same stuff but I have 10uF as C2 for such function (as per TI documentation Fig. 19).
    Here is PCB footprint (C2=C32, R3=R22, R7=R25,C9=C5,C23=C3)). C2 is on input. Maybe something I'm missing here? Thx
  6. bertus
    bertus Moderator
    1,339
    526
    Nov 8, 2019
    Hello,
    In the layout in the datasheet there are not such small traces.
    They use complete planes for the connections.
    They also show where vias are planned:
    Bertus
  7. jozef007
    jozef007
    23
    Nov 9, 2019
    Thank you for guidelines, but is such change, via way how I did PCB, effect so much function? I don't have so much knowledge to explain it...
  8. Hunter64
    Hunter64
    44
    13
    Nov 20, 2018
    "As for all switching power supplies, the layout is an important step in the design, especially at high peak currents and high switching frequencies. If the layout is not carefully done, the regulator could show stability problems as well as EMI problems."
    Just a quote from the datasheet mentioned in the first post.
  9. jozef007
    jozef007
    23
    Nov 9, 2019
    Word is around, that I need to pay more attention to the documentation... Must admit, they are some improvements need to be done :)
    Let's assume that I will follow PCB footprint to the letter, otherwise there is not visible issue in schematic itself? Just reminding that I will have input 1.8-2.8 V and output 5V with expecting load max 1.5V. Thx
  10. jozef007
    jozef007
    23
    Nov 9, 2019
    I get verified that schematic is correct. I will create new PCB layout and hopefully will work. Thx for assistance. I'm concluding problem as resolved.
