Problem using a mosfet to switch devices on/off
Discussion in 'Electronic Design' started by galapogos, Jan 30, 2007.
  1. galapogos
    galapogos Guest
    I'm trying to use a MOSFET whose gate is controlled by an MCU to
    switch on/off the Vcc of 2 devices. I'm using a spare TP0610 P channel
    enhancement mode vertical DMOSFET to accomplish this. Here are the
    connections.
    Source - 3.3V
    Gate - MCU control output and 50K pullup(hence default switched OFF)
    Drain - device Vcc and 1M pulldown(hence Vcc = 0V when mosfet OFF)
    When I take the MCU out of the picture and simply use a jumper to
    ground the gate input, and using this to switch the devices on/off, it
    works perfectly. However, when I use the MCU to control the gate
    voltage, I get some problems.
    1) Drain voltage is initially 0V when power is applied. However, when
    my MCU switches the mosfet ON and then OFF again, drain voltage
    sometimes doesn't return back to 0V, but is about 1.2V
    2) When the MCU tries to switch the mosfet ON by applying a logic 0,
    my multimeter says it's not actually 0V but more like 300+mV. Does
    this cause any problems, and why is logic 0 so high in the first
    place?
    I'm having some intermittent problems so I suspect that my hardware's
    the problem here. Judging from the behavior and measurement I'm
    getting this may very well be the case.
    Any thoughts/suggestions/fixes?
    Thanks!
  2. CBFalconer
    CBFalconer Guest
    I'll give good odds that changing the pullup from 50k to 10k or
    4.7k will cure it. Things leak.
  3. Maybe you're connecting more than just the MCU to those switches-- and
    the MCU is partially powering the devices through it's outputs and the
    input protection diodes on whatever you are switching. If that seems
    likely, try programming any such outputs to go low before you cut the
    Vcc.
    The 300mV does not make much sense, so it bears further investigation.
    Scope the line to make sure there are not pulses on there, and check
    that there is no voltage differential on your grounds.
    Best regards,
    Spehro Pefhany
  4. galapogos
    galapogos Guest
    Wow you're a genius. I figured that out after tracing my code to where
    the problem starting appearing, and indeed it's the TX line that's
    causing the problem. 1 of my devices communicates with the MCU's UART
    and when I turned Vcc off, the TX was still set to output high. I set
    it to become an input instead and now I get close to 0V when turning
    off Vcc. Why would the TX matter though?
    The weird thing is that the 300mV only happens when I upload my
    firmward to my flash MCU. When I'm debugging on my emulator, I get a
    pretty clean 0V(<100mV at least).
