Problem - Triangle Wave Generator
Discussion in 'General Electronics Discussion' started by Farrukh12, Mar 27, 2013.
  1. Farrukh12
    Farrukh12
    4
    Mar 27, 2013
    I have made a triangle wave generator in Proteus but my circuit gives not output.
    I have also tried different values of R2 and C1 but still no output.
    my input voltage is 12V.
    I want my output wave frequency to be around 10 kHz
  2. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    That circuit should work. What are you connecting to the two voltage input points (top end of R5, and pin 8 of the op-amp)? They should both be connected to your +12V supply.
    If you can't get the circuit working, post the voltages on all pins of the op-amp.
  3. Miguel Lopez
    Miguel Lopez
    252
    63
    Jan 25, 2012
    Doesn't you circuit work in Proteus or in the real world?
    I had some similar problem using EWB 5.1. But in the protoboard it worked fine
  4. Farrukh12
    Farrukh12
    4
    Mar 27, 2013
    it doesnt work in proteus
  5. Farrukh12
    Farrukh12
    4
    Mar 27, 2013
    why do i need to post voltages at all pins of the op amp
  6. duke37
    duke37
    5,364
    771
    Jan 9, 2011
    To know the state that the amps are stuck in.
  7. Miguel Lopez
    Miguel Lopez
    252
    63
    Jan 25, 2012
    Mount it in a protoboard or similar. It should work. That circuit is almost infallible.
