W
Watson A.Name - \Watt Sun, the Dark Remover\
I and probably a lotta other people have a chronic problem that is in
need of a simple solution. We're about to move into a new bldg and I
have to do a lotta install'ns of PCs, etc., so I'm under the desk a lot.
Every room in the new bldg has the motion sensors that turn off the
lights after a few minutrd, and I have to continually get up and wave my
arms to reactivate the sensors.
Some of the sensors are PIR motion detectors, and some are ultrasonic.
The US ones could be fooled with a fan in front of the sensor, But how
can I fool a PIR motion sensor? I have to have a warm, moving body in
front of the sensor, maybe a caged animal? Or a long wave IR generator
that moves or generates an intermittent output. I've ruled out candles
or other flames for safety reasons. A friend suggested a Lavalamp might
work, but I don't think I want to wait ten or twenty minutes to warm it
up. Maybe one of those old lamps with the rotating picture and fan
blades on top, that turns by convection currents from the light bulb
heat. I know that the IR output from IR LEDs is much too short a
wavelenght. Any ideas? Thanks.
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
