problem in timing simulation
Discussion in 'Electronic Design' started by [email protected], Aug 22, 2005.
  1. Guest
    Hi all,
    The following piece of code works in functional simulation
    --This process is used to detect the start condition(I2C).
    -- SDA is used as the clock for this purpose
    process(sda,sys_reset,current_i2c_state,scl)
    begin
    if(sys_reset='0' or current_i2c_state= I2C_HEADER)then
    detect_start <= '0';
    elsif(sda='0' and sda'event)then
    if(scl/= '0')then
    detect_start <= '1';
    else
    end if;
    end if;
    end process;
    In functional sim it works fine but when i do the timing simulation
    even when the condition is satisfied the detct_start dosen't go high.
    Note: This is the start detction logic for I2C .Since SCL and SDA are
    externally pulled up '1' is converted to a 'Z'(not shown here).
    But same is the case for funstional simulation.
    the sda will aways be either '0' or 'Z' never a '1'.
    I am using modelsim simuator to perform timing simulation .
    and industry standard SDO file generated by altera.
    Any suggestions appreciated.
    Thanks in advance,
    Praveen
  2. While I don't know what your timing simulation problem is, I do have a
    suggestion (or maybe three). ;-) I would take "scl" out of the
    sensitivity list. You've described an asynchronous reset negative-edge
    triggered D-FF. The "scl" term isn't in the asynchronous reset logic
    or clock, so it shouldn't be in the sensitivity list. While this
    *shouldn't* cause your problem, it will affect simulation performance.
    It may drive some simulators bonkers too.
    The other thing that strikes me is the logic being done in the reset
    statement. I don' tknow the technology you're targeting here, but in
    many this is a no-no. The resets should be clean. Be careful with
    asynchronous resets too.
    Maybe something like:
    process(sda,sys_reset)
    begin
    if sys_reset='0'
    then detect_start <= '0';
    elsif sda='0' and sda'event -- <== falling_edge(sda)
    then
    if current_i2c_state = I2C_HEADER
    then
    elsif(scl/= '0')
    then detect_start <= '1';
    else detect_start <= '0';
    end if;
    end if;
    end process;
    This causes the current_i2c_state "reset" to be synchronous, but will
    be more technology (and static timing analysis) friendly.
    I also use the VHDL '93 riding_edge(), falling_edge(), functions
    because they're easier for me to read.
    OTOH, maybe a synchronous reset D-FF would be better:
    PROCESS(sda)
    BEGIN
    IF falling_edge(sda)
    THEN
    IF sys_reset = '0'
    OR current_i2c_state = I2C_HEADER
    THEN
    ELSIF(scl/= '0')
    THEN detect_start <= '1';
    THEN detect_start <= '0';
    END IF;
    END IF;
    END PROCESS;
