Problem in Process corner simulation using Cadence ADXL tool.
Discussion in 'PCB Layout, Design and Manufacture' started by Alex_Bam, Mar 4, 2021.
  1. Alex_Bam
    Alex_Bam
    21
    Sep 28, 2020
    Hello,
    My question is related to CADENCE software simulation.
    I am doing a process corner simulation of a simple inverter using ADXL in CADENCE. But the problems are:
    1_ When I run only the nominal corner it simulates successfully as shown in the figure.
    2-But when I add worse power /worse speed corner scenario for CMOS then individually it runs, however when I combine different corners (e.g. nominal, wort power, and worst speed scenarios) then it not simulating and showing a pending option [attached]. Moreover in remarks, it shows the following message:
    net /Vin selected but not highlighted
    net /Vout selected but not highlighted
    To make it simple, individual corner simulation runs successfully but it does not simulate in the case of combined process corners. And I would like to simulate all the corners simultaneously so that I can compare my simulation result under different scenarios.
    Can anyone have faced a similar problem or suggest to me possible ways to solve it?
    Thanks.
