Probes for Oscilloscope
Discussion in 'Troubleshooting and Repair' started by gavb, Feb 7, 2011.
  1. gavb
    gavb
    4
    Feb 23, 2010
    Hi I have just bought my first Oscilloscope which is an old Telequipment D1015. It is a 15Mhz one but it didn't come with any probes. My understanding is I cant just get a BNC cable and solder croc clips to the end. When I search google for 15mhz probes the only ones I can find are £74 which seams a little much. Can I use any probes. ie. ones rated at 60Mhz? if not where can i get some cheap ones?
    Thanks Gavin
  2. (*steve*)
    25,496
    2,837
    I would look at something like this.
    Probably (certainly) not the best probes in the world, but enough to get you started.
  3. gavb
    gavb
    4
    Feb 23, 2010
    thanks for the reply
    Im in the UK so if I find any probe that is rated as 15mhz or higher then that would be fine?
    I am only working with analogue audio equipment.
    Thanks gavin
  4. (*steve*)
    25,496
    2,837
    Well, kinda. You preferably want correctly matching 15MHz probes. 20MHz is probably close enough. Higher frequency probes may have incorrect capacitance leading to waveforms being deformed too much to be corrected by the probe adjustment.
    Your scope will probably have a test point on it that produces a square wave. This is used as a reference when you're adjusting the probe. The manual should describe how to do it (you adjust the probe until the square wave looks squarest!)
    Check that place again. The price includes postage. :)
  5. gavb
    gavb
    4
    Feb 23, 2010
    thanks
    Wow I cant believe they offer free shipping to the UK. Thank you very much for that
