Printer Port Connectors "DB" and "db"
Discussion in 'Electronic Basics' started by Searcher7, Mar 1, 2009.
  1. Searcher7
    Searcher7 Guest
    I picked up some female DB25 to db25 connectors that I'll need to
    install in the walls of of some project boxes, that I've yet to get,
    and realize that a "DB" is a different connector than a "db".
    I guess it's not a big deal because either way I have to connect one
    side to terminal strips. But having to buy another kind of adaptor
    seems redundant.
    Does there exist crimp pins that I could plug into the db25 side?
    Any suggestions on a way to make this connection would be appreciated.
    (I'm using 20g leads).
    Thanks a lot.
    Darren Harris
    Staten Island, New York.
  2. Searcher7
    Searcher7 Guest
    Well, I won some connectors on eBay: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180282704904
    And only one side fits my printer cable. The other side has the
    correct spacing but is loose meaning the holes are larger.
    Also, I have no idea who the manufacturer is of these.(There is a
    little insignia that looks something like an "S/A").
    Thanks.
    Darren Harris
  3. Searcher7
    Searcher7 Guest
    There is another sign stamped on it, but it doesn't look like a
    letter.
    I can't be sure, but I see no pins inside either. Can "insertable
    contacts" be gotten from anywhere?
    Thanks.
    Darren Harris
  4. Yes, they are without pins.
  5. Jasen Betts
    Jasen Betts Guest
    looks like part of a configurable DB25F to modular socket patch
    connectoer, eg.
    http://cdlnz.com/index.html?do=viewproduct&code=A-D25FRJ45&ID=1048641
    (you have the part on the right.)
    individual inserts are also avalable, leaded.
    http://cdlnz.com/index.html?do=viewproduct&code=A-JW-F&ID=1048658
    and uncrimped,
    http://cdlnz.com/index.html?do=viewproduct&code=CP-F&ID=1049500
    These have been re-branded "dynAmix" I don't know who the original
    supplier was.
    bye.
  6. Jasen Betts
    Jasen Betts Guest
    on second thought, I have handled them and they look very similar the
    drawing in the datasheet here
    http://nz.farnell.com/spc-technology/spc15221/telephone-adapter/dp/1185855
    I can't say if these are yours.
    possibly the E-Bay vendor can supply the pin inserts, or tell you
    where to order them.
