Printer port confusion
Discussion in 'Electronic Basics' started by Randy Day, Jan 4, 2007.
  1. Randy Day
    Randy Day Guest
    Is there a reason why different websites list different
    signal states on some parallel port pins? Are some just
    wrong, or were there two types of parallel ports for
    PC's at one time?
    For example:
    http://et.nmsu.edu/~etti/fall96/computer/printer/printer.html
    indicates that pins 10 and 15 are inverted inputs, while
    http://ourworld.compuserve.com/homepages/Bill_Bowden/page6.htm#p_input
    has 10 and 15 as _normal_ inputs while *11* is inverted!
    I just found out my PC has the latter pinout, while I
    had wired a ciruit assuming that the first website (and
    another that agreed with it) were correct.
    <grumble>
    I just want to know if I'm going to have problems with
    pinouts if I want to hook a microcontroller to different
    PC's and their parallel ports.
  2. Sjouke Burry
    Sjouke Burry Guest
    welll... i think the info below would be of use....
    PC Parallel Port Mini-FAQ
    By Kris Heidenstrom (), revision 4, 950403
    In no event shall the author be liable for any damages whatsoever
    for any loss relating to this document. Use it at your own risk!
    1. INTRO
    This is a five printed page mini-FAQ with the information essential
    for programming the PC parallel port. Many subjects are not covered
    in detail. View on an 80-column monospaced screen with 8-column tab
    stops. Comments and suggestions to .
    A parallel port links software to the real world. To software, the
    parallel port is three 8-bit registers occupying three consecutive
    addresses in the I/O space. To hardware, the port is a female 25-pin
    D-sub connector, carrying twelve latched outputs from the computer,
    accepting five inputs into the computer, with eight ground lines.
    The normal function of the port is to transfer data to a parallel
    printer through the eight data pins, using the remaining signals as
    flow control and miscellaneous controls and indications.
    The original port was implemented with TTL/LS logic. Modern ports are
    implemented in an ASIC or a combined serial/parallel port chip, but
    are backward compatible. Some modern ports are bidirectional.
    2. BIOS LPT PORT TABLE
    A parallel port is identifed by its I/O base address, and also by its
    LPT port number. The BIOS power-on self-test checks specific I/O
    addresses for the presence of a parallel port, and builds a table of
    I/O addresses in the low memory BIOS data area, starting at address
    0040:0008 (or 0000:0408).
    This table contains up to three 16-bit words. Each entry is the I/O
    base address of a parallel port. The first word is the I/O base
    address of LPT1, the second is LPT2, etc. If less than three ports
    were found, the remaining entries in the table are zero. DOS, and
    the BIOS printer functions (accessed via int 17h), use this table to
    translate an LPT port number to a physical port at a certain address.
    The addresses are checked in a specific order, and addresses are put
    into the table as they are found, so the table will never have gaps.
    A particular I/O address does not necessarily always equate to the
    same specific LPT port number, although there are conventions.
    2.1 ADDRESSING CONVENTIONS
    The video card's parallel port is normally at 3BCh. This address is
    checked first by the BIOS, so if a port exists there, it will be LPT1.
    The BIOS then checks at 378h, then at 278h. AFAIK there is no
    standard address for a fourth port, and BIOSes only look for three.
    3. DIRECT HARDWARE ACCESS
    The port consists of three 8-bit registers at adjacent addresses in
    the processor's I/O space. The registers are defined relative to
    the I/O base address, and are at IOBase+0, IOBase+1, and IOBase+2
    (for example if IOBase is 3BCh, then the registers are at 3BCh,
    3BDh, and 3BEh). Always use 8-bit I/O accesses on these registers.
    3.1 DATA REGISTER
    The data register is at IOBase+0. It may be read and written (using
    the IN and OUT instructions, or inportb() and outportb() or inp()
    and outp()). Writing a byte to this register causes the byte value
    to appear on pins 2 through 9 of the D-sub connector (unless the port
    is bidirectional and is set to input mode). The value will remain
    latched and stable until you write another value to the data
    register. Reading this register yields the state of those pins.
    7 6 5 4 3 2 1 0
    * . . . . . . . D7 (pin 9), 1=High, 0=Low
    . * . . . . . . D6 (pin 8), 1=High, 0=Low
    . . * . . . . . D5 (pin 7), 1=High, 0=Low
    . . . * . . . . D4 (pin 6), 1=High, 0=Low
    . . . . * . . . D3 (pin 5), 1=High, 0=Low
    . . . . . * . . D2 (pin 4), 1=High, 0=Low
    . . . . . . * . D1 (pin 3), 1=High, 0=Low
    . . . . . . . * D0 (pin 2), 1=High, 0=Low
    3.2 STATUS REGISTER
    The status register is at IOBase+1. It is read-only (writes will be
    ignored). Reading the port yields the state of the five status input
    pins on the parallel port connector at the time of the read access:
    7 6 5 4 3 2 1 0
    * . . . . . . . Busy . . (pin 11), high=0, low=1 (inverted)
    . * . . . . . . Ack . . (pin 10), high=1, low=0 (true)
    . . * . . . . . No paper (pin 12), high=1, low=0 (true)
    . . . * . . . . Selected (pin 13), high=1, low=0 (true)
    . . . . * . . . Error. . (pin 15), high=1, low=0 (true)
    . . . . . * * * Undefined
    3.3 CONTROL REGISTER
    The control register is at IOBase+2. It is read/write:
    7 6 5 4 3 2 1 0
    * * . . . . . . Unused (undefined on read, ignored on write)
    . . * . . . . . Bidirectional control, see below
    . . . * . . . . Interrupt control, 1=enable, 0=disable
    . . . . * . . . Select . . (pin 17), 1=low, 0=high (inverted)
    . . . . . * . . Initialize (pin 16), 1=high, 0=low (true)
    . . . . . . * . Auto Feed (pin 14), 1=low, 0=high (inverted)
    . . . . . . . * Strobe . . (pin 1), 1=low, 0=high (inverted)
    3.3.1 BIDIRECTIONAL CONTROL BIT
    The bidirectional control bit is only supported on true bidirectional
    ports - on other ports, it behaves like bits 7 and 6. On a proper
    bidirectional port, setting this bit to '1' causes the outputs of the
    buffer that drives pins 2 through 9 of the 25-pin connector to go into
    a high-impedance state, so that data can be _input_ on those pins.
    In this state, values written to the data register will be stored in
    the latch chip, but not asserted on the connector, and reading the
    data register will yield the states of the pins, which may be driven
    by an external device without stressing or damaging the port driver.
    Also note that on some machines, another port must be set correctly
    to enable the bidirectional features, in addition to this bit.
    I suspect this applies to machines with the parallel port integrated
    on the motherboard as part of the motherboard chipset, but I do not
    have details, sorry.
    On some parallel port cards, bidirectional mode must be enabled by a
    jumper setting. With this setting enabled, the bidirectional
    control bit will be able to enable the bidirectional input mode.
    3.3.2 INTERRUPT ENABLE BIT
    The parallel port interrupt was intended to be used for interrupt
    driven transmission of data to a parallel printer, but DOS and BIOS
    do not use it. Versions of OS/2 prior to Warp (3.0) did require the
    interrupt for printing, but from Warp onwards the interrupt is not
    required (though it can be used if the /IRQ switch is provided on
    the line in CONFIG.SYS, i.e. BASEDEV=PRINT0x.SYS /IRQ).
    For experimenters, the interrupt facility is useful as a general
    purpose externally triggerable interrupt input.
    The interrupt control bit controls a tristate buffer that drives the
    IRQ line. Setting the bit to '1' enables the buffer, and an IRQ will
    be triggered on each falling edge (high to low transition) of the Ack
    signal on pin 10 of the 25-pin connector. Disabling the interrupt
    allows other devices to use the IRQ line.
    The actual IRQ number is either hardwired (by convention, the port at
    3BCh uses IRQ7), or is jumper-selectable (IRQ5 is a common choice).
    Sound cards, in particular, tend to use IRQ7 for their own purposes.
    To use the IRQ you must also enable the interrupt via the interrupt
    mask register in the interrupt controller, at I/O address 21h, and
    your interrupt handler must send an EOI on exit. DOS technical
    programming references have notes on writing interrupt handlers.
    3.3.3 PRINTER CONTROL BITS
    The bottom four bits are latched and presented on the parallel port
    connector, much like the data register. Three of them are inverted,
    so writing a '1' will output a low voltage on the port pin for them.
    These four outputs are open collector outputs with pullup resistors,
    so an external device can force them low without stressing the driver
    in the PC, and they can even be used as inputs.
    To use them as inputs, write 0100 binary to the bottom four bits of
    the control register. This sets the outputs all high, so they are
    pulled high by the pullup resistors (typically 4700 ohms). An
    external device can then pull them low, and you can read the pin
    states by reading the control register. Remember to allow for the
    inversion on three of the pins.
    If you are using this technique, the control register is not strictly
    'read/write', because you may not read what you write (or wrote).
    4 SAMPLE PROGRAM - DETERMINE WHETHER A PORT IS BIDIRECTONAL
    This program reports for LPT1, LPT2, and LPT3 whether the port exists
    and whether it is bidirectional, i.e. setting the bidirectional control
    bit causes the port to go into high-impedance (tri-state) mode. This
    program is written for Borland C. Change outportb() and inportb() to
    outp() and inp() for Microsoft C, I think. I did not have a machine
    with a bidirectional port with which to test this program fully, so
    please drop me a line if you can confirm that it does or doesn't work.
    Save this code to BIDIR.C and compile with:
    bcc -I<include_path> -L<library_path> bidir.c
    --------------------------- snip snip snip ---------------------------
    #include <dos.h>
    #include <process.h>
    #include <stdio.h>
    /* The following function returns the I/O base address of the nominated
    parallel port. The input value must be 1 to 3. If the return value
    is zero, the specified port does not exist. */
    unsigned int get_lptport_iobase(unsigned int lptport_num) {
    return *((unsigned int far *)MK_FP(0x40, 6) + lptport_num);
    /* Checks whether the port's data register retains data, returns 1 if
    so, 0 if not. The data register retains data on non-bidirectional
    ports, but on bidirectional ports in high impedance (tri-state)
    mode, the data register will not retain data. */
    unsigned int test_retention(unsigned int iobase) {
    outportb(iobase, 0x55); /* Write a new value */
    (void) inportb(iobase); /* Delay */
    if (inportb(iobase) != 0x55) {
    return 0; /* Did not retain data */
    outportb(iobase, 0xAA); /* Write another new value */
    if (inportb(iobase) != 0xAA) {
    return 1; /* Retained data alright */
    void report_port_type(unsigned int portnum) {
    unsigned int iobase, oldctrl, oldval;
    iobase = get_lptport_iobase(portnum);
    if (iobase == 0) {
    printf("LPT%d does not exist\n", portnum);
    return;
    oldctrl = inportb(iobase+2);
    outportb(iobase+2, oldctrl & 0xDF); /* Bidir off */
    oldval = inportb(iobase); /* Keep old data */
    if (test_retention(iobase) == 0) {
    printf("LPT%d appears to be faulty!\n", portnum);
    outportb(iobase+2, oldctrl);
    outportb(iobase, oldval);
    return;
    outportb(iobase+2, oldctrl | 0x20); /* Bidir on */
    printf("LPT%d %s bidirectional\n", portnum,
    (test_retention(iobase)) ? "is not" : "is");
    outportb(iobase+2, oldctrl); /* Put it back */
    outportb(iobase, oldval); /* Restore data */
    return;
    void main(void) {
    unsigned int portnum;
    for (portnum = 1; portnum < 4; ++portnum)
    report_port_type(portnum);
    exit(0);
    5. FILE TRANSFER PROGRAM CABLES
    The parallel-to-parallel cable is used by DRDOS's INTERLNK program.
    Apparently Laplink and FastLynx cables are the same. The pin-to-pin
    connection between two male 25-pin D-sub connectors is: 2-15, 3-13,
    4-12, 5-10, 6-11, and the reverse: 15-2, 13-3, 12-4, 10-5, and 11-6,
    and ground: 25-25. This requires eleven wires. If you have spare
    wires, link some extra grounds together. Pins 18 to 25 inclusive are
    grounds. A very long cable may be unreliable, limit it to 10 metres.
    6. TRANSFERRING DATA BETWEEN TWO COMPUTERS USING PARALLEL PORTS
    The normal method uses the file transfer program cable described
    above, which sends data port bits 0-4 of one machine to status port
    bits 3-7 (respectively) on the other, and vice versa. Data is sent
    four bits at a time, using the fifth lines in each direction as data
    strobe and acknowledge respectively. Some protocol is required to
    control the data direction.
    Here are some sample functions that will send and receive a byte of
    data using the above cable. One program must be the sender and one
    must be the receiver. The input_value() function will be used on
    both sender and receiver. The receive_byte() function will be used
    only on the receiver. The transmit_byte() function will be used only
    on the sender, and will wait without returning, until the byte has
    been received and acknowledged by the receiver.
    static unsigned int lpt_base; /* Set to base I/O address */
    /* Return input value as 5-bit number. If input has changed since this
    function was last called, verify that the input is stable. */
    unsigned int input_value(void) {
    static unsigned char last_value = 0xFF;
    auto unsigned char new1, new2;
    new1 = inportb(lpt_base + 1) & 0xF8;
    if (new1 != last_value) {
    for (;;) {
    new2 = inportb(lpt_base + 1) & 0xF8;
    if (new2 == new1) /* Wait for stable value */
    break;
    new1 = new2;
    last_value = new1;
    return (last_value ^ 0x80) >> 3;
    /* Receive an 8-bit byte value, returns -1 if no data available yet */
    signed int receive_byte(void) {
    unsigned int portvalue, bytevalue;
    portvalue = input_value(); /* Read input */
    if ((portvalue & 0x10) == 0)
    return -1; /* Await high flag */
    outportb(lpt_base, 0x10); /* Assert reverse flag */
    bytevalue = portvalue & 0x0F; /* Keep low nibble */
    do {
    } while ((portvalue & 0x10) != 0); /* Await low flag */
    outportb(lpt_base, 0); /* Deassert reverse flag */
    bytevalue |= (portvalue << 4); /* High nibble */
    return bytevalue & 0xFF;
    /* Transmit an 8-bit byte value, won't return until value is sent */
    void transmit_byte(unsigned int val) {
    val &= 0xFF;
    outportb(lpt_base, (val & 0x0F) | 0x10); /* Set nibble flag */
    while ((input_value() & 0x10) == 0)
    ; /* Await returned flag high */
    outportb(lpt_fase, val >> 4); /* Clear nibble flag */
    while ((input_value() & 0x10) != 0)
    ; /* Await returned flag low */
    return;
    End of the PC Parallel Port Mini-FAQ.
    Kris
  3. There USED to be a standard - Centronics - which many computers used. All
    Radio Shack computers used that standard. For reasons only they know IBM
    used the standard serial port as a connector and changed the use of some
    pins. This became the new standard and, as a result, some ignorant people
    say that Radio Shack "didn't follow the standard" which is stupid because
    IBM wasn't making the PC in 1977.
    IBM also screwed up the serial port standard by using the other polarity
    connector for that.
  4. John G
    John G Guest
    I think you are wrong.
    IBM never confused the serial and parallel ports.
    They just chose to use a 9 pin connector for the serial signals because
    they did not need any more and there was not room on one card for the
    normal 25 pin connector for the Centronics printer interface and an
    RS232 serial service.
  5. Bob Masta
    Bob Masta Guest
    The other problem you will encounter is that modern
    Windows PCs no longer have a software-accessible printer
    port. Up through Win9x you could access it directly,
    but now it requires a Ring 0 driver to allow access
    by your software. GIVEIO and USERPORT are two
    that I have heard of, but haven't used.
    Best regards,
    Bob Masta
    dqatechATdaqartaDOTcom
    D A Q A R T A
    Data AcQuisition And Real-Time Analysis
    www.daqarta.com
    Scope, Spectrum, Spectrogram, Signal Generator
    Science with your sound card!
  6. When the "IBM PC" came along, they used a 25 pin connector for the
    serial port, and a 25 pin connector for the parallel port. The same
    25-pin connectors that had previously been the domain of serial ports.
    It was only later that they started using a 9-pin connector for the serial
    port.
    Michael
  7. The problem is likely bigger than that, if the computer is new enough.
    I gather they aren't putting serial and parallel ports on computers nowadays,
    instead opting for USB for that sort of expansion. Even this 1GHz Pentium
    has only one of each, and unlike the days of the ISA bus, I'll have to go
    out and buy a PCI card if I want to expand those. My previous computer at
    least still had an ISA bus so I could dig through the box of boards and
    find all kinds of serial and parallel boards.
    Michael
  8. Randy Day
    Randy Day Guest
    Bob Masta wrote:
    [snip]
    Yeah, I already knew about that. I'm working
    with 9x boxes for the moment...
    Now THOSE two I hadn't heard of before!
    <fires up google>
