Prefered: Undervolt or Overvolt a circuit?
Discussion in 'General Electronics Discussion' started by sharpbiohazard, Sep 12, 2012.
  1. sharpbiohazard
    sharpbiohazard
    4
    Sep 12, 2012
    I have just finished building a color organ circuit from canakit.com http://www.canakit.com/3-channel-ac-colour-organ-kit-ck185-uk185.html
    The kit calls for a regulated 12v DC supply in order to power the functions on the board. I have found an unregulated [email protected] DC supply and have built the common LM317 voltage regulator circuit to keep it under control. The kit pulls around 100mA while operating.
    My problem is-
    I cannot get an exact 12v value out of the voltage regulator, based on the restrictions of common value resistors. I can either choose to go 11.8v, or 12.4 volts.
    My question is-
    What is better for the circuit? Provide it with a little more voltage, or a little less?
  2. john monks
    john monks
    693
    Mar 9, 2012
    I would pick 11.8 volts.
    If I am looking at the right part of the spec it says that a 9 volt source or a 12 volt source can be used.
  3. BobK
    7,682
    1,688
    You are also not likely to get more than 10V from an LM317 with input of 12V.
  4. sharpbiohazard
    sharpbiohazard
    4
    Sep 12, 2012
    The supply is kicking out ~19v, since it is unregulated.
  5. BobK
    7,682
    1,688
    Okay, you might get by then with a current draw well below the rating of the power supply.
