Precision 5V reference
Discussion in 'Datasheets, Manuals and Component Identification' started by prescott2006, Nov 15, 2010.
  1. prescott2006
    prescott2006
    9
    Oct 9, 2010
    Anyone can suggest a very precise and constant 5V reference? I Google and see many are recommend LT1085 and LM317? Which one is better? Any better recommendation?
  2. (*steve*)
    25,501
    2,841
    Define precise (over input voltage, time, load, and temperature?) Is noise a consideration?
    The LM317 isn't a precision regulator.
    Do you really want a 5V reference, or a 5V supply? (i.e. what current are you needing)?
  3. prescott2006
    prescott2006
    9
    Oct 9, 2010
    I want to have a constant 5V source in my circuit. Like I supply 12 V, then I will get a very precise 5V voltage. Precise in term of the 5V will as constant as possible no matter how is the load and the fluctuation of the input voltage.
  4. (*steve*)
    25,501
    2,841
    OK, sounds like you simply need a regulator.
    Google 7805
  5. prescott2006
    prescott2006
    9
    Oct 9, 2010
    But is it 7805 output reliable? Won't it fluctuate too much from 5V?
  6. (*steve*)
    25,501
    2,841
    You have yet to define what limits you have.
    From your explanation it sounds like all you need is a 5V regulator.
    If it's any more complex we need details.
    "As constant as possible" is NOT sufficient (it is pretty meaningless)
    Have a look at the datasheet for the 7805 and tell us if there are any of its specs that fall outside your required parameters, and by how much.
  7. bean
    bean
    4
    Oct 21, 2010
  8. barathbushan
    barathbushan
    223
    Sep 26, 2009
    That's link is not really helpful
