Precise location sensor
Discussion in 'Electrical Engineering' started by Tman, Sep 22, 2012.
  1. Tman
    Tman Guest
    Does anyone know of a technology, module, chip that can do precise locationdetermination...
    I need something that can get 4cm (centimeters) or better repeatable (not absolute) location accuracy, in an area approx 100m x 100m (or so)... 1 update per second is fine.
    I am pretty sure that this is beyond the capability of GPS.
    I can envision a "local LORAN-like" solution consisting of: 3 fixed stations, 1 which is a master transmitter, and the other two of which transmit a different frequency, but with a phase-locking arrangement. Then, the sensor would need to sense these 3 frequencies, do a phase difference determination, and then use this to augment a GPS coordinate with a hyperbolic line of transmission.
    Just as a reasonability check, 10degrees of phase at 150MHZ works out to something like 5cm or so. Higher frequencies being even more precise.
    Thanks for any ideas, before I go about building something like this myself!
    Tman
  2. Guest
    I meant "line of location"...
  3. Rich.
    Rich. Guest
    Doesn't that Roomba self-driving vacuum do that?
