I've used copper water pipe, 22mm in U.K. Just flatten the ends in a vice
and drill. Took about 90 mins to join 16 batteries in a four x four
configuration. You can sleeve the copper with plastic drain pipe where
desired. Voltage losses are < 1mV at max current.
