PRBS generator with rsds tx
Discussion in 'Electronic Design' started by Iterativeend, Apr 10, 2007.
  1. Iterativeend
    Iterativeend Guest
    Is it possible to have an internal 23 bit PRBS generator for a rsds
    transmitter using a 7 phase PLL without a high speed clock and still
    maintain 2^23-1 unique bits?
  2. Guest
    A psuedo-random binary sequence is just a string of binary numbers -
    8,388,607 for the 23-it case.
    How you generate it is irrelevant. You could read it out of memory if
    necessary, though this uses up a lot more silicon than a 23-bit shift
    register and an exclusive-OR gate.
    Win Hill's "The Art of Electronics" includes a useful discussion of
    the subject starting at section 9.32.
  3. Rich Grise
    Rich Grise Guest
    Is there an algorithm for figuring out which bits to XOR to get the
    maximum length sequence for a given size of SR, or is it just
    by-guess-and-by-gosh?
    Rich
  4. Guest
    According to "The Art of Electronics" the criterion for maximal length
    is that the polynomial
    1 + x^n + x^m
    must be polynomial and prime over the Galois field, where m is the
    length of the shift register in bits, and n is the tap number.
    I tried to make sense of a similar assertion when looking at error-
    detecting and error-correcting codes back in 1970, and didn't get
    anywhere at all. Mathematicians who study the algebra of finite fields
    seem to do better.
  5. Tom Bruhns
    Tom Bruhns Guest
    So the algorithm is to try a set of feedback bits and see if it meets
    the requirement. There IS a maximal length sequence for all shift
    register lengths; in fact, there are huge numbers of them for long
    shift registers. It's relatively quite easy to determine the number
    of maximal length polynomials of a given order. Finding them for long
    registers--high orders--is not necessarily easy (or fast). However,
    once you've found one, you can generate lots of others easily. For
    some cases, there are not any feedback schemes using only two values
    xored together; for some you need to modulo-2 sum four bits, minimum.
    (It's relatively easy to show that you always need an even number of
    bits fed back, and it should be obvious that you always must include
    the last bit.) You can find lists of feedback that works--of maximal
    length polynomials. The ap notes on the Xilinx web site has one such
    list, up to some pretty long sequences. Finding a maximal length
    polynomial for some arbitrary but high order (hundreds or even
    thousands) would be a good task for the idle time of processors
    distributed around the world, connected by the internet. That's been
    used to find some related numbers...numbers such that 2^n-1 is prime.
    How those are related to maximal length shift registers is left for
    another day...
    Cheers,
    Tom
  6. Tom Bruhns
    Tom Bruhns Guest
    Ok, Spehro, exactly what is the difference between the polynomials
    listed in the app note and "a Galois LFSR"? How might the latter be
    faster?
    AFAIK, I can make a shift register whose natural response is
    represented by any boolean polynomial you wish, within the limits of
    being able to clock all the bits simultaneously, and the speed is
    reduced only by increased capacitive loading on the output register.
    Cheers,
    Tom
  7. Xilinx app note XAPP 052 lists the taps up to 168 bits, but maybe a
    Galois LFSR might be better for hardware inplementation if speed is an
    issue.
    Best regards,
    Spehro Pefhany
  8. joseph2k
    joseph2k Guest
    That was the low hanging fruit, how do you apply a 7 phase PLL to an rsds
    transmitter? How does it interact with the prbs generator?
  9. Iterativeend
    Iterativeend Guest
    Basically you use a 7 phase PLL to fetch data from 7 parallel ports.
    But if the same method is used to get values from 7 random points on a
    23 bit PRBS generator, we would end up with sequences repeating at
    random and before the end of a single cycle of the prbs generator.
    @Rich, Maxim has a list of tap points for 2-32 bit PRBS here,
    http://www.maxim-ic.com/appnotes.cfm?appnote_number=1743&CMP=WP-9
  10. Guest
    How the hell would I know? I don't know what an rsds transmitter is,
    and I've no idea how it uses a 7-phase PLL.
    This doesn't invalidate the useful point I made about generating
    psuedo-random binary sequences - you don't have to use a tapped shift
    register as the source of the bit sequence.
  11. Iterativeend
    Iterativeend Guest
    Basically, you would use a serializer to fetch and serialize data from
    7 parallel ports(using the 7 phases of the PLL) before the rsds or any
    other diff. driver. But if a built in 23 bit PRBS generator is used to
    check the quality of the serializer and driver, it would normally be
    expected to travel the same path a data would. So that would mean that
    somehow we have to serialize the 23 PRBS gen data such that only 7
    bits are obtained per clock and yet maintain the 23 bit
    characteristics like 8 million + sequences.
    If i just serialize any 7 consecutive ports from the PRBS gen, its not
    exactly a 23 bit generator. It can be achevied if i use 7 * 23 MUX,
    but its not practical to use that many MUXes.
  12. Tom Bruhns
    Tom Bruhns Guest
    So...clock the LFSR seven times to get the seven bits you want.
    What? You want to do it in ONE clock? Fine, no problem. If you
    express what happens in the LFSR as a matrix equation, x(k+1)=A*x(k),
    where the matrix multiplication is performed with modulo-2
    arithmetic. So then x(k+7)=A^7*x(k). Figure out what A^7 is, and
    implement what it implies. Depending on just what taps are fed back
    in your desired sequence, it's likely going to be easier than you
    think. With only the end and one other tap fed back, there are a lot
    of zeros in the A matrix. You can even trick Matlab or Scilab into
    doing the modulo-2 multiplication for you.
    Cheers,
    Tom
  13. Tom Bruhns
    Tom Bruhns Guest
    Also...since 2^23-1 = 8388607 = 47 * 178481 which are both prime, then
    taking 7 bits at a time won't repeat till you've clocked 7 bits out
    2^23-1 times. That is, you'll go seven times around the cycle before
    the bits appear in the same places again. Of course, you'll repeat 7-
    bit words a whole lot of times, since there are only 128 unique 7 bit
    words.
    Cheers,
    Tom
