Powertip grafic 320x240 lcd module (SED1335)
Discussion in 'Electronic Design' started by neo644, May 27, 2004.
  1. neo644
    neo644 Guest
    Hello, im using a powertip 320x240 lcd module, which uses the sed1335
    controler. im also using an Atmel uc, the ATmega8515.
    I was wondering if anybody has used this controler with this uc, or
    not, but i would apreciate any code examples for the initialization
    routine.
    and another question, how can i find out if the lcd module is
    "Single-Panel Drive" or "Double-Panel Drive" ? the module is:
    PG320240FRS-DE4-H-A1
    thank you.
  2. I wrote a quick hack to test this display. You are welcome to look at
    it and adapt it to your application.
    It's single panel drive.
    John Devereux
    /* 1/4 VGA with SED1335 controller - test program */
    /* avr specific definitions */
    #define CTL PORTC
    #define CTL_DDR DDRC
    #define DATA PORTA
    #define DATA_IN PINA
    #define DATA_DDR DDRA
    /* connections to control port - all "normally high" */
    #define RD 0 /* active low read strobe */
    #define WR 1 /* active low write strobe */
    #define A0 2 /* selects command/data */
    #define CS 3 /* active low lcd chip select strobe */
    #define RES 4 /* active low reset strobe */
    /* SED1335 specific definitions */
    #define CMD_SYSTEM 0x40
    #define CMD_SLEEP 0x53
    #define CMD_SCROLL 0x44
    #define CMD_CSRFORM 0x5d
    #define HDOTS 320
    #define VDOTS 240
    #define SX (HDOTS/8)
    #define START (0x2000)
    /* write data byte (A0 low) */
    inline static void wr_data(uint8_t x)
    DATA = x;
    CTL &= ~(1<<A0 | 1<<CS | 1<<WR);
    CTL |= (1<<A0 | 1<<CS | 1<<WR);
    /* write control byte (A0 high) */
    inline static void wr_ctl(uint8_t x)
    DATA = x;
    CTL &= ~(1<<CS | 1<<WR);
    CTL |= (1<<CS | 1<<WR);
    /* read data byte (A0 high) */
    static uint8_t rd(void)
    uint8_t x;
    DATA_DDR=0;
    CTL &= ~(1<<CS | 1<<RD);
    asm("nop");
    asm("nop");
    x = inp(PINA);
    CTL |= (1<<CS | 1<<RD);
    DATA_DDR=0xff;
    return x;
    /* read status byte (A0 low) */
    static uint8_t rd_ctl(void)
    uint8_t x;
    DATA_DDR=0;
    CTL &= ~(1 << A0 | 1<<CS | 1<<RD);
    asm("nop");
    x = inp(PINA);
    asm("nop");
    CTL |= (1<<A0 | 1<<CS | 1<<RD);
    DATA_DDR=0xff;
    return x;
    /* set cursor address */
    inline static void set_address(unsigned int address)
    wr_ctl(0x46);
    wr_data(address % 0x100);
    wr_data(address / 0x100);
    void lcd_wr(uint8_t *src, unsigned dst, int len)
    set_address(dst);
    wr_ctl(0x42);
    while(len--)
    DATA = *src++;
    void lcd_rd(unsigned src, uint8_t *dst, int len)
    set_address(src);
    wr_ctl(0x43);
    DATA_DDR=0;
    while(len--)
    asm("nop");
    asm("nop");
    *dst++ = inp(PINA);
    DATA_DDR=0xff;
    void lcd_clr(void)
    int len=32768;
    set_address(START);
    wr_ctl(0x42);
    while(len--)
    DATA = 0;
    /* initialise display */
    void lcd_init(void)
    wr_ctl(CMD_SYSTEM);
    wr_data(0x30); /* single panel, IV set */
    wr_data(0x07); /* FX, WF 8 colummn chars, WF flag set */
    wr_data(0x07); /* FY8 row characters */
    wr_data(39); /* C/R roughly, "chars/row" */
    wr_data(39+4); /* TC/R "Total chars/row" including blanking*/
    wr_data(239); /* L/F "lines per frame?" */
    wr_data(40); /* APL "Address Pitch (Low)" (of "virtual" screen) */
    wr_data(0); /* APH */
    /* display on */
    wr_ctl(0x59);
    /* no cursor, turn on first screen block (only), no flashing */
    wr_data(0x04);
    /* SCROLL command (setup regions) */
    wr_ctl(0x44);
    /* SAD1L,SAD1H,SL1 region 0 address start at 0x0000*/
    wr_data(START%0xff);
    wr_data(START/0x100);
    wr_data(240);
    /* SAD2L, SAD2H, SL2 */
    wr_data(0);
    wr_data(0);
    wr_data(240);
    /* SAD3L, SAD3H */
    wr_data(0);
    wr_data(0);
    /* 16x16 block cursor */
    wr_ctl(CMD_CSRFORM);
    wr_data(0x1);
    wr_data(0x81);
    set_address(START);
    /* cursor direction: forward */
    wr_ctl(0x4c);
    /* select overlay config */
    wr_ctl(0x5b);
    /* select graphics mode for screens 1 and 3*/
    wr_data(0x0c);
    lcd_clr();
    /* cursor off */
    wr_ctl(0x59);
    /* no cursor, turn on first screen block only, no flashing */
    wr_data(0x04);
    int main(void)
    unsigned i;
    XP_TRACE_PORT=0;
    XP_TRACE_DDR=0xff;
    osHardwareInit();
    DATA_DDR = 0xff;
    /* control signals are all "normally high" */
    CTL |= 1<<RD | 1<<WR | 1<<A0 | 1<<CS | 1<<RES;
    CTL_DDR = 1<<RD | 1<<WR | 1<<A0 | 1<<CS | 1<<RES;
    /* pulse reset low for 100ms */
    CTL &= ~(1<<RES);
    osDelayms(2);
    CTL |= (1<<RES);
    osDelayms(4);
    lcd_init();
    /* displays a letter "A" */
    uint8_t A[]=
    0x10,0x10,0x28,0x28,0x44,0x7c,0x82,0x82
    set_address(START);
    wr_ctl(0x42);
    for(i=0;i<40*240;i++)
    if(i%40 == 10 && (i/40)>7 && (i/40)<16)
    wr_data(A[(i/40)%8]);
    else wr_data(0);
    for(;;) osTraceToggle(1);
