Powering x-opto white LEDs
Discussion in 'Electronic Design' started by Alex Bird, Oct 28, 2004.
  1. Alex Bird
    Alex Bird Guest
    I'm making some LED lights for illumination as part of some costumes,
    in fact I have to put these things together tomorrow!
    In my prototype I used some ultra-bright reds I had lying around, and
    my series resistance calculations were fine. The device is simply a
    D-type flip-flop, reed switch and npn transistor, enabling the light
    to be switched on and off by waving it near a magnet.
    For the real things I ordered these:
    http://www.rapidelectronics.co.uk/r...CAT_CODE=30319&STK_PROD_CODE=M61376&XPAGENO=2
    Made by X-opto. Who they?? I cannot find any online presence.
    Lens Material V F max V R max Chromaticity [email protected] View angle
    water clear GaN 4.2V 5V X=0.31, Y=0.32 3000 15°
    As the intensity is quoted for 20mA, I factored in the forward drop of
    0.7V per LED and calculated the resistance. Nothing. I Checked all
    my cables, measured voltages.
    Eventually I tried upping the current, and finally with 5V connected
    directly across them they are putting out what looks like 3000mcd to
    me!
    Am I right in thinking that I can do this because VFmax is 4.2V, and
    4.2 + 0.7 = about 5? Am I wrong to assume a forward drop of 0.7V?
    Does anyone know anything about these LEDs?
    Thanks for any help,
    Alex
  2. Tim Wescott
    Tim Wescott Guest
    LEDs have a different forward drop from a silicon diode -- red ones can
    range from 1.5V on up. In your case I think you need to use the 4.2V
    instead of 0.7V in your calculations.
