Powering a radio with solar cells
Discussion in 'General Electronics Discussion' started by 8bit, Aug 9, 2015.
  1. 8bit
    8bit
    97
    3
    Oct 30, 2013
    I have a very small radio that takes two AAA batteries and runs on a total of 3volts. I would like to add a solar cell to it so I can run it without batteries. I am just a little confused as how to connect it to the power connecters at the back. The back of the radio is shown below.
    [​IMG]
  2. davenn
    davenn Moderator
    13,381
    1,784
    hi ya
    the negative from the panel goes to the spiral terminal on the lower left
    the positive from the panel goes to the terminal that cant be seen just above the lower left terminal
    NOTE you will need a panel that can produce around 4 - 4.5V as it will drop to around 3V when under load
    MOST panels voltage rating is an open circuit voltage rating. Confirm the O.C. voltage before you buy the panel
  3. 8bit
    8bit
    97
    3
    Oct 30, 2013
    Ah, thank you for clearing that up. I have a 3v solar cell and just no matter how I wired it I could not get any power in the radio. :)
  4. davenn
    davenn Moderator
    13,381
    1,784
    is that 3V open circuit ?
    measure the voltage with the radio as a load once wired to the radio correctly
    you may find the voltage is dropping to 2V or less ( you may need 2 cells in series)
  5. Colin Mitchell
    Colin Mitchell
    1,418
    314
    Aug 31, 2014
    A single solar cell is 0.5v
  6. 8bit
    8bit
    97
    3
    Oct 30, 2013
    That's the voltage across just the solar panel on it's own.
  7. davenn
    davenn Moderator
    13,381
    1,784
    OK then it will drop substantially when a load is applied maybe as low as 1V, so you may need 2 or 3 in series
  8. 8bit
    8bit
    97
    3
    Oct 30, 2013
    Thanks Dave, I'll try and pick up a couple more. Thanks for the information. :)
