powering 1 watt luxeon off 12 volts (car battery)
Discussion in 'Hobby Electronics' started by mark krawczuk, Apr 12, 2005.
  1. hi , i`m pretty sure i asked this some time ago , but i`ve forgotten, i
    want to run a red 1 watt luxeon, and a 1 watt amber luxeon off 12 volts,
    car battery.
    what value and wattage resister would i need. or is there a formula for
    working out the required resistors ?
    thanks.
    mark k
    "Are you still wasting your time with spam?...
    There is a solution!"
    Protected by GIANT Company's Spam Inspector
    The most powerful anti-spam software available.
    http://mail.spaminspector.com
  2. Ken Taylor
    Ken Taylor Guest
    If they are the same as the ones in the RS catalog, the Vf is 2V at 20mA, so
    for a 12V battery you'd need a 500 Ohm resistor. If it's actually 13.8V then
    you'd need a 690Ohm. A 680 Ohm may do the trick; I'd be hesitant to
    over-drive one of these as I seem to recall people saying they don't like it
    (heatsink the blighter!). A proper regulator circuit is recommended IIRC.
    Ken
  3. hi, whats IIRC?
    thanks.
    mark k
  4. Pippa Reeves
    Pippa Reeves Guest
    IIRC =
    If I Remember Correctly
  5. Mike
    Mike Guest
    Ken clearly doesn't remember correctly, because 2V @ 20mA is only 40mW -
    nowhere NEAR 1Watt! His formula is for a bog ordinary red LED.
  6. You need Ohms Law and the Luxeon LED specs.
    At a maximum battery voltage of 13.8V, with a drop of around 2.9V
    across the LED (same for red and amber) and a maximum current of 350mA
    you'd be looking at around a 31ohm resistor at almost 4W.
    Round that up to the nearest prefered value of 33ohms. A 5W resistor
    would work but it will get HOT. Better to use say a 10W.
    Dave :)
  7. Andrew M
    Andrew M Guest
    Use an LM317 configured as a constant current generator. Then you're not
    dependant on battery voltage. You can also run both LEDs in series if
    necessary, which results in the LEAST dissipation in the LM317.
    There is a formula - it's Ohms law.
    R=E/I. E=voltage across the resistor, I= current through the resistor
    -Andrew M
  8. Franc Zabkar
    Franc Zabkar Guest
    It's The Uppercase Version Of iirc. Like When You Use The Shift Key.
    - Franc Zabkar
