I have moved my Piano and when I put it on now it trips the main power. I had already replace the fuse but it's still the same. Can someone please help.
I'm with duke37. Check ALL the cables that were installed. It's possible something internally was knocked loose in the physical moving, but twisted/ run-over, or pulled-loose cable connectors would be the things I'd check first.
