Power Transistors wanted
Discussion in 'Hobby Electronics' started by Phillip Truscott, May 13, 2006.
  1. Both with TO-3 cases. 2SD 188 npn & 2SA 627 pnp, or nearest equivalent
    equal to or better than, will suffice. for repair of old audio amplifier.
  2. Phil Allison
    Phil Allison Guest
    "Phillip Truscott"
    ** A 2N3055 and MJ2955 pair would do just fine.
    The two you mention have power and current specs well under the 3055.
    ........ Phil
  3. Thank you very much. I will now fix the amp, and at least it should work again,
    even if it isn't still all original parts.
    But I would also like to know where I could get hold of a T0-3 socket. As one of
    them was removed from the amp.:
    Yours Sincerely,
    Phillip Truscott.
    Mailto:
  4. Phil Allison
    Phil Allison Guest
    "Phillip Truscott"
    ** See:
    http://www.altronics.com.au/index.asp?area=item&id=P2301
    ........ Phil
