Power Transformer Heat Load
Discussion in 'General Electronics Discussion' started by Gristle McThornbody, Apr 20, 2012.
  1. Gristle McThornbody
    Gristle McThornbody
    31
    Mar 14, 2012
    I've got a power transformer where I will use only half of the center tapped secondary. I think I can push slightly higher-than-design current through that half because I'm not creating as much heat in the transformer as I would if I were using the entire secondary winding. Is that correct?
    I recognize that the actual winding will have localized heating problems if I overload it with amps, but if I use only half the winding, I'm thinking my overall tranformer heat load should be less.
  2. (*steve*)
    25,501
    2,841
    If it's a centre tapped transformer, and if you have a bridge rectifier on half of it, you should consider changing to a configuration which uses 2 diodes and the full winding.
  3. Gristle McThornbody
    Gristle McThornbody
    31
    Mar 14, 2012
    Oops, I think I kind of skipped right past that idea.
    If I do it with full wave rectification the way you suggested, I should get the same overall voltage and current capability, while just spreading the power and heat load more evenly throughout the transformer, right?
  4. (*steve*)
    25,501
    2,841
    This should answer your question.
