Power Supplys
Discussion in 'Electronic Basics' started by AMX, Feb 3, 2006.
  1. AMX
    AMX Guest
    I have got some DC Power Supplys for some projects one 6 volt and one 5
    volt the 5 volt one reads 5.5volts but the 6 volt one reads 8.1 volts
    the circuit board that it is powering says 5 to 7.5 volts will it be ok
    with it and also i tested some more power supplys and some read close
    to the output voltage and others where way off like a 12 volt one said
    18 volts why is this? cheers
  2. Ralph Mowery
    Ralph Mowery Guest
    What kind of power supplies ?
    If they are the wall cube types, they are not usually regulated and the
    unloaded voltage will be somewhat high. As you put a load on them , the
    voltage will drop near the rated voltage.
