power supply
Discussion in 'Electronic Design' started by Mitian, Mar 15, 2007.
  1. Mitian
    Mitian Guest
    I wanted to build a variable dc supply with maximum voltage of
    12v.When the resistance across the rehiostat is zero the regulator
    output is 12v. But the output increases above 12v when Ivary the
    resistance across the rehiostat above zero.Is that what should happen?
    if yes why is that? if no what should i do? If you can suggest me
    another way of desigening variable dc power supply also....
  2. Eeyore
    Eeyore Guest
    It'll depend on the circuit which we don't have available to make any useful
    comment. Is it available online ?
    Graham
    Ethiopia btw ?
