Power supply
Discussion in 'Power Electronics' started by Jeanguypataterubberboot, Jul 20, 2013.
  1. Jeanguypataterubberboot
    41
    Jul 9, 2013
    I'm looking for advice on a power supply. I've narrowed it down to the bk precision 1686b, 1687b or 1688b. Just not sure if higher voltage or amperage is more important. I can't imagine I would need 60 volts for much. Although 20 amps might come in handy for powering a mobile hf radio one day. Also I wand to power breadboard circuits so accuracy and not overshooting voltage is important. Wouldn't want a spike to kill my project.
    Any suggestions would be appreciated.
    Pierre
  2. KMoffett
    KMoffett
    723
    75
    Jan 21, 2009
    I suggest you not look for a one-size-fits-all power supply. Get a +/-0to15V-1A and +5V/5A combined supply for the breadboard stuff. Also a 12/24v-30A supply for mobile radios. But, no idea what the 60V is needed for.
    Ken
  3. Jeanguypataterubberboot
    41
    Jul 9, 2013
    Thanks for the advice. Is that because the lower voltage ones are more precise for breadboard circuits?
  4. Jeanguypataterubberboot
    41
    Jul 9, 2013
    Also can you recommend a brand that has good specs?
  5. KMoffett
    KMoffett
    723
    75
    Jan 21, 2009
    Generally, yes.
    Ken
  6. Jeanguypataterubberboot
    41
    Jul 9, 2013
    Specs on a power supply
    I'm thinking of purchasing this power supply. It's a BK Precision 1687b. It meets all my requirements.
    I don't know much about the numbers behind the specs as I aim new to these. Can anyone tell me if these numbers represent good quality for a bench power supply?
    Number of outputs 1
    Load regulation Voltage: Less than or equal to 50mV (millivolts); Current: Less than or equal to 100mA (milliamp)
    Line regulation Voltage: Less than or equal to 20mV; Current: Less than or equal to 50mA
    Ripple and noise Less than or equal to 5mV RMS (root mean square), or less than or equal to 50mV peak to peak
    Ripple current Less than or equal to 30mA RMS
    Meter accuracy + or – 2% + 3 counts
    Transient response time 1.5ms (milliseconds)
    Switching frequency 100 to 120kHz
    Power requirements 100 to 240VAC at 50 to 60 Hz
    Operating temperature and humidity 32 to 104 degrees F/0 to 40 degrees C, less than or equal to 80% relative humidity
    Standards met European Conformity (CE) marking
    Weight 2.4kg/5.2lb.
    Dimensions 90 x 200 x 208mm/3.5 x 7.9 x 8.2 inches (H x W x D)
    Thanks for the help.
    Pierre
  7. (*steve*)
    25,496
    2,837
    Here is a review of the 1697. Is it similar?
    Dave also gives you some information on the company.
  8. davenn
    davenn Moderator
    13,833
    1,950
    Pierre
    PLEASE dont start multiple threads on the same subject !!
    I have deleted one and merged the other intop this thread
    DAve
