Power Supply Switching & charging battery
Discussion in 'Power Electronics' started by EEngineer93, Feb 28, 2021.
  1. EEngineer93
    EEngineer93
    5
    Feb 28, 2021
    [​IMG]
    So my aim is create/find a circuit that will switch between 2 power supplies as follows:
    1- When generator is [OFF] - The battery will power the load
    2- When generator is [ON] - The generator will power the load and supply power to the charger in order to charge the battery.
    Note: Switching between both supplies must be done simultaneously to ensure no interruption of power.
    Thank you!
      File size:
      10.8 KB
      6
  2. Harald Kapp
    11,153
    2,547
    Seamless switching can be done with two diodes:
    Note that the generator needs to supply a slightly higher voltage than the battery. Otherwise the battery would power the load all the time.
  3. EEngineer93
    EEngineer93
    5
    Feb 28, 2021
    Good idea, now how would I go about supplying power to the charger this way? I believe supplying the charger before the diode on the gen side would work, correct?
  4. Harald Kapp
    11,153
    2,547
    Like this:
    EEngineer93 likes this.
