P
Phil Allison
"klem kedidelhopper"
What you're referring to is a 12VCT transformer. Connecting either a
bridge and not using a center tap or just two diodes across the full
secondary with cathodes tied together using CT as common connected to
an output filter will yield 18VDC.
** Fucking BULL SHIT !!!!!!!!!!!!!!
** Then explain how every other person on the planet get a different result
Using a CT as common halves the voltage from the tranny and so halves the DC
voltage as well.
My god you are fucking stupid.
..... Phil
If you have done this and gotten 36 volts, then you actually have a
48V transformer with CT>
Jamie
I've tried it and it does
voltage as well.
..... Phil
