Power supply high voltage
Discussion in 'General Electronics Discussion' started by Fractus, Jan 3, 2021.
  1. Fractus
    Fractus
    18
    Dec 31, 2020
    Why is the power supply has a higher voltage? Power adapter.JPG Multimeter.JPG
  2. bertus
    bertus Moderator
    2,506
    977
    Nov 8, 2019
    Hello,
    Could it be that the powersupply is unregulated?
    If so, the voltage should go down under load.
    Bertus
  3. Fractus
    Fractus
    18
    Dec 31, 2020
    The powersupply is regulated.
  4. bertus
    bertus Moderator
    2,506
    977
    Nov 8, 2019
    Hello,
    How can you tell it is regulated?
    It is not noticed on the power supply.
    Bertus
    davenn likes this.
  5. Harald Kapp
    12,455
    2,985
    That is a contradiction. When regulated, the output voltage should be 4.5 V.
    From the single 220 V input rating I take it this is a transformer based power supply. This type of wall wart quite often consists of a transformer, rectifier and capacitor only. Put a load to the output, around 220 Ω to draw the rated 20 mA, check the voltage again with load.
    bertus likes this.
  6. bertus
    bertus Moderator
    2,506
    977
    Nov 8, 2019
    Hello,
    @Harald Kapp , The power supply is rated for 400 mA.
    The given 20 mA is for the 220 Volts side.
    Bertus
  7. Fractus
    Fractus
    18
    Dec 31, 2020
    But if I check the voltage on load does it bust my device?
  8. bertus
    bertus Moderator
    2,506
    977
    Nov 8, 2019
    Hello,
    As Halrald said, try a resistor (or a small lightbulb from 4.5 or 6 volts torch) as load and see if the voltage goes down.
    Bertus
  9. Harald Kapp
    12,455
    2,985
    Oops, I goofed. Thanks for the correction.
    Anyway, 220 Ω should suffice to load the output.
  10. Harald Kapp
    12,455
    2,985
    Use a bare resistor as load, the risk is very low that it gets damaged, And if so, so what? It's only a resistor.
    Do not use an electronic device you want to keep in working order.
  11. ColKlonk
    ColKlonk
    15
    3
    Dec 22, 2020
    Those power supplies are rated at the current specified. This is an unregulated power supply.
    In the picture you should get 4.5 Volts when drawing 400mA, the voltage climbing as you draw less current, and visa-versa.
    It's done this way because of the transformer and secondary winding resistance losses, and what you've measured there is the 'no-load' voltage.
    You can now draw a 'straight line' V-I graph to see the voltage-current relationship of the power supply, so if the tranformer can handle a short circuit ;), you would get around 800mA at around 0 Volts. (Don't do this though - it'll cook the transformer)
Similar Threads
Loading...
