Power Supply for DC Motor
Discussion in 'Power Electronics' started by loldollard, Jan 8, 2013.
  1. loldollard
    loldollard
    Jan 8, 2013
    Hello all, I was wondering if anyone can help with a little problem...
    I have an 18v DC motor which is currently being powered by a lithium ion battery. I would like to power it with a power supply instead (240v AC i/p). When running (not under load) current is around 7amps. Under load is around 14 amps, however the motor spikes to 31 amps upon startup for less than a second.
    I'm not that knowledgeable with power supplies - are they able to cope with the spike or do I need to have everything rated to 32 amps plus?
    Thanks in advance, Laurence
Similar Threads
Loading...
