Power supply 230Vac 12V - 24Vdc
Discussion in 'Electronic Design' started by Gerard, Mar 19, 2013.
  1. Gerard
    Gerard Guest
    Hello to all.
    I am searching for a multivoltage power supply which are to be mounted on the DIN rail of a cabinet.
    What I am actually interested in are 12Vdc and 24Vdc outputs with an input of 230Vac. The loads I am considering
    in my circuit draw about 1 Amp from the 12Vdc source and about 3Amps from the 24Vdc source.
    As I am designing a redundant power supply I would need to have 2 Power supplies in parallel so in case one fails
    the other takes over so I would also like to know whether the power supplies have an incorporated diode that idealizes this function.
    I am also considering using one of the 12Vdc power supplies with a dual output for this function. By connecting the both 12V
    outputs in a series connection I would have my 24Vdc and at the 12V nodes i could power my 12V load.
    Another option would be to get the 24Vdc power supply and using a resistive bridge or zener diode lower the voltage to 12Vdc or another integrated
    circuit ...however I would have to cope with heating losses and high wattage extra components.
    Could you please advice me on my best options.
    I am familiar with TDK Lambda power supplies for DIN Rails. As this is circuit has to always work I would need a reliable and top notch manufacturer.
    Thanks in advance.
    Gerard
  2. Meanwell has some DIN rail supplies. If it really has to always work,
    you'll need to find another approach (for example hot swap and
    redundancy) than just buying good or expensive supplies because
    _everything_ eventually fails, and power supplies will often fail
    before other things.
